Have you been using any skins to replace the default ones? I used one for a Galil and I had no reload sound at all. Perhaps its just a specific server you were on? as some of them use custom radio commands.
have a look at your sound settings and if neccesary unistall, reinstall the game for it to be fresh. either youve downloaded some sounds or your sound card drivers are playing up.
