Nagios - no check_snmp plugin
8 Mar 2007
between here and there
hey guys,
I've been trawling the internets for days now and I@m not getting anywhere :(
I have installed nagios 3.2.3 on fedora 14 but no matter how many perl, snmp, lib and dev packages I install and no matter how many time I run ./configure then make and make install i still can't get check_snmp to appear in the libexec folder.
Now I'm a noob when it comes to linux so please be gentle.
I've copied the log I created from the ./configure on v15 of nagios plugins in case anyone can spot anything i can't.
Thanks in advance :)
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking whether gcc needs -traditional... no
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for ar... ar
checking for strip... strip
checking for ranlib... (cached) ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether gcc and cc understand -c and -o together... yes
checking for error_at_line... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking for working strtod... yes
checking for python... /usr/bin/python
checking for sh... /bin/sh
checking for perl... /usr/bin/perl
checking for libgnutls-config... no
checking for hostname... /bin/hostname
checking for basename... /bin/basename
checking for main in -ldce... no
checking for main in -lnsl... yes
checking for socket in -lsocket... no
checking for main in -lresolv... yes
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking for floor in -lm... yes
checking for plan_tests in -ltap... no
checking for main in -lcrypt... yes
checking for PQsetdbLogin in -lpq... no
checking for rc_read_config in -lradiusclient... no
checking for rc_read_config in -lradiusclient-ng... no
checking for main in -lldap... yes
checking for ldap_set_option... yes
checking for ldap_init... yes
checking for ldap_set_option... (cached) yes
checking for ldap_get_option... yes
checking for ldap_start_tls_s... yes
checking linux/hdreg.h usability... yes
checking linux/hdreg.h presence... yes
checking for linux/hdreg.h... yes
checking linux/types.h usability... yes
checking linux/types.h presence... yes
checking for linux/types.h... yes
checking for mysql_config... no
checking for IPv6 support... yes
checking krb5.h usability... yes
checking krb5.h presence... yes
checking for krb5.h... yes
checking for dlopen in -ldl... yes
checking for shl_load in -ldl... no
checking openssl/ssl.h usability... yes
checking openssl/ssl.h presence... yes
checking for openssl/ssl.h... yes
checking openssl/x509.h usability... yes
checking openssl/x509.h presence... yes
checking for openssl/x509.h... yes
checking openssl/rsa.h usability... yes
checking openssl/rsa.h presence... yes
checking for openssl/rsa.h... yes
checking openssl/pem.h usability... yes
checking openssl/pem.h presence... yes
checking for openssl/pem.h... yes
checking openssl/crypto.h usability... yes
checking openssl/crypto.h presence... yes
checking for openssl/crypto.h... yes
checking openssl/err.h usability... yes
checking openssl/err.h presence... yes
checking for openssl/err.h... yes
checking for CRYPTO_lock in -lcrypto... yes
checking for main in -lssl... yes
checking whether time.h and sys/time.h may both be included... yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking uio.h usability... no
checking uio.h presence... no
checking for uio.h... no
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking sys/poll.h usability... yes
checking sys/poll.h presence... yes
checking for sys/poll.h... yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking stdarg.h usability... yes
checking stdarg.h presence... yes
checking for stdarg.h... yes
checking sys/unistd.h usability... yes
checking sys/unistd.h presence... yes
checking for sys/unistd.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking for an ANSI C-conforming const... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for pid_t... yes
checking for size_t... yes
checking return type of signal handlers... void
checking for va_copy... yes
checking for memmove... yes
checking for select... yes
checking for socket... yes
checking for strdup... yes
checking for strstr... yes
checking for strtol... yes
checking for strtoul... yes
checking for floor... no
checking for poll... yes
checking return type of socket size... int
checking for ps... /bin/ps
checking for ps syntax... /bin/ps axwo 'stat uid pid ppid vsz rss pcpu comm args'
checking for ping... /bin/ping
checking for ping6... /bin/ping6
checking for ICMP ping syntax... /bin/ping -n -U -w %d -c %d %s
checking for ICMPv6 ping syntax... /bin/ping6 -n -U -w %d -c %d %s
checking for nslookup... /usr/bin/nslookup
checking for nslookup syntax... /usr/bin/nslookup -sil
checking for number of cpus... sysconf(_SC_NPROCESSORS_CONF)
checking for uptime... /usr/bin/uptime
checking for rpcinfo... no
checking for lmstat... no
checking for smbclient... no
checking for who... /usr/bin/who
checking for snmpget... /usr/bin/snmpget
checking for snmpgetnext... /usr/bin/snmpgetnext
checking for Net::SNMP perl module... found
checking for quakestat... no
checking for qstat... no
checking for fping... no
checking for ssh... /usr/bin/ssh
checking for mailq... /usr/bin/mailq
checking for qmail-qstat... no
checking for swap... no
checking for swapinfo... no
checking for lsps... no
checking for sys/stat.h... (cached) yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking for sys/swap.h... yes
checking whether swapctl is declared... no
checking for swaptbl_t... no
checking for swapent_t... no
checking for struct swapent.se_nblks... no
checking for /proc/meminfo... found /proc/meminfo
checking for dig... /usr/bin/dig
checking for apt-get... no
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for ld used by GCC... /usr/bin/ld
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
checking for main in -lpthread... yes
checking for working alloca.h... yes
checking for alloca... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for errno.h... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking for sys/param.h... (cached) yes
checking sys/vfs.h usability... yes
checking sys/vfs.h presence... yes
checking for sys/vfs.h... yes
checking sys/fs_types.h usability... no
checking sys/fs_types.h presence... no
checking for sys/fs_types.h... no
checking for sys/socket.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking xlocale.h usability... yes
checking xlocale.h presence... yes
checking for xlocale.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for math.h... (cached) yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for unistd.h... (cached) yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking for stdint.h... (cached) yes
checking wchar.h usability... yes
checking wchar.h presence... yes
checking for wchar.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking for sys/time.h... (cached) yes
checking wctype.h usability... yes
checking wctype.h presence... yes
checking for wctype.h... yes
checking whether the preprocessor supports include_next... yes
checking for inline... inline
checking for C/C++ restrict keyword... __restrict
checking whether <wchar.h> uses 'inline' correctly... yes
checking for btowc... yes
checking for dup2... yes
checking for fcntl... yes
checking for getdtablesize... yes
checking for mbsinit... yes
checking for mbrtowc... yes
checking for mprotect... yes
checking for memchr... yes
checking for alarm... yes
checking for nl_langinfo... yes
checking for lstat... yes
checking for isblank... yes
checking for iswctype... yes
checking for wcscoll... yes
checking for setenv... yes
checking for strdup... (cached) yes
checking for strndup... yes
checking for localtime_r... yes
checking for timegm... yes
checking for pipe... yes
checking for vasnprintf... no
checking for wcrtomb... yes
checking for iswcntrl... yes
checking for iswblank... yes
checking for nl_langinfo and CODESET... yes
checking for a traditional french locale... fr_FR
checking whether byte ordering is bigendian... no
checking whether system is Windows or MSDOS... no
checking whether // is distinct from /... no
checking if environ is properly declared... yes
checking for complete errno.h... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... yes
checking for working fcntl.h... yes
checking for mode_t... yes
checking for promoted mode_t type... mode_t
checking whether <sys/socket.h> is self-contained... yes
checking for shutdown... yes
checking whether <sys/socket.h> defines the SHUT_* macros... yes
checking for struct sockaddr_storage... yes
checking for sa_family_t... yes
checking whether socket is declared without a macro... no
checking whether connect is declared without a macro... no
checking whether accept is declared without a macro... no
checking whether bind is declared without a macro... no
checking whether getpeername is declared without a macro... no
checking whether getsockname is declared without a macro... no
checking whether getsockopt is declared without a macro... no
checking whether listen is declared without a macro... no
checking whether recv is declared without a macro... no
checking whether send is declared without a macro... no
checking whether recvfrom is declared without a macro... no
checking whether sendto is declared without a macro... no
checking whether setsockopt is declared without a macro... no
checking whether shutdown is declared without a macro... no
checking whether accept4 is declared without a macro... no
checking whether getaddrinfo is declared without a macro... yes
checking whether freeaddrinfo is declared without a macro... yes
checking whether gai_strerror is declared without a macro... yes
checking whether getnameinfo is declared without a macro... yes
checking for library containing gethostbyname... none required
checking for gethostbyname... yes
checking for library containing getservbyname... none required
checking for getservbyname... yes
checking for IPv4 sockets... yes
checking for IPv6 sockets... yes
checking for library containing inet_ntop... none required
checking whether inet_ntop is declared... yes
checking for getopt.h... (cached) yes
checking for getopt_long_only... yes
checking whether optreset is declared... no
checking whether getopt_clip is declared... no
checking whether getopt is POSIX compatible... yes
checking for working GNU getopt function... yes
checking whether getenv is declared... yes
checking whether getc_unlocked is declared... yes
checking whether we are using the GNU C Library 2.1 or newer... yes
checking for wchar_t... yes
checking whether NULL can be used in arbitrary expressions... yes
checking whether malloc, realloc, calloc are POSIX compliant... yes
checking for GNU libc compatible malloc... yes
checking for long long int... yes
checking for mbstate_t... yes
checking for a traditional japanese locale... ja_JP
checking for a transitional chinese locale... zh_CN.GB18030
checking for a french Unicode locale... fr_FR.UTF-8
checking for mmap... yes
checking for MAP_ANONYMOUS... yes
checking whether memchr works... yes
checking for ssize_t... yes
checking whether setenv validates arguments... yes
checking search.h usability... yes
checking search.h presence... yes
checking for search.h... yes
checking for tsearch... yes
checking whether snprintf is declared... yes
checking for stdbool.h that conforms to C99... yes
checking for _Bool... yes
checking for unsigned long long int... yes
checking whether C symbols are prefixed with underscore at the linker level... no
checking whether strdup is declared... yes
checking for working strerror function... yes
checking whether memmem is declared without a macro... yes
checking whether mempcpy is declared without a macro... yes
checking whether memrchr is declared without a macro... yes
checking whether rawmemchr is declared without a macro... yes
checking whether stpcpy is declared without a macro... yes
checking whether stpncpy is declared without a macro... yes
checking whether strchrnul is declared without a macro... yes
checking whether strdup is declared without a macro... yes
checking whether strncat is declared without a macro... yes
checking whether strndup is declared without a macro... yes
checking whether strnlen is declared without a macro... yes
checking whether strpbrk is declared without a macro... yes
checking whether strsep is declared without a macro... yes
checking whether strcasestr is declared without a macro... yes
checking whether strtok_r is declared without a macro... yes
checking whether strsignal is declared without a macro... yes
checking whether strverscmp is declared without a macro... yes
checking whether strndup is declared... (cached) yes
checking whether strnlen is declared... (cached) yes
checking whether stat file-mode macros are broken... no
checking for struct timespec in <time.h>... yes
checking for wint_t... yes
checking for intmax_t... yes
checking whether snprintf returns a byte count as in C99... yes
checking for snprintf... yes
checking for strnlen... yes
checking for wcslen... yes
checking for wcsnlen... yes
checking for mbrtowc... (cached) yes
checking for wcrtomb... (cached) yes
checking whether _snprintf is declared... no
checking whether vsnprintf is declared... yes
checking for alloca as a compiler built-in... yes
checking whether inet_ntop is declared without a macro... yes
checking whether inet_pton is declared without a macro... yes
checking whether btowc(0) is correct... yes
checking whether btowc(EOF) is correct... yes
checking whether // is distinct from /... (cached) no
checking whether dup2 works... yes
checking for error_at_line... (cached) yes
checking whether fcntl handles F_DUPFD correctly... yes
checking whether fcntl understands F_DUPFD_CLOEXEC... needs runtime check
checking whether fcntl is declared without a macro... yes
checking whether openat is declared without a macro... yes
checking whether floorf is declared... yes
checking for sys/mount.h... yes
configure: checking how to get file system space usage
checking for statvfs function (SVR4)... no
checking for 3-argument statfs function (DEC OSF/1)... no
checking for two-argument statfs with statfs.bsize member (AIX, 4.3BSD)... yes
checking dustat.h usability... no
checking dustat.h presence... no
checking for dustat.h... no
checking sys/fs/s5param.h usability... no
checking sys/fs/s5param.h presence... no
checking for sys/fs/s5param.h... no
checking sys/filsys.h usability... no
checking sys/filsys.h presence... no
checking for sys/filsys.h... no
checking sys/statfs.h usability... yes
checking sys/statfs.h presence... yes
checking for sys/statfs.h... yes
checking for statfs that truncates block counts... no
configure: checking how to do getaddrinfo, freeaddrinfo and getnameinfo
checking for library containing getaddrinfo... none required
checking for getaddrinfo... yes
checking for gai_strerror (possibly via ws2tcpip.h)... yes
checking for struct sockaddr.sa_len... no
checking whether getaddrinfo is declared... (cached) yes
checking whether freeaddrinfo is declared... (cached) yes
checking whether gai_strerror is declared... (cached) yes
checking whether getnameinfo is declared... (cached) yes
checking for struct addrinfo... yes
checking for gethostname... yes
checking for HOST_NAME_MAX... yes
checking for getloadavg... yes
checking for pstat_getdynamic... no
checking for kstat_open in -lkstat... no
checking for perfstat_cpu_total in -lperfstat... no
checking whether getloadavg requires setgid... no
checking sys/loadavg.h usability... no
checking sys/loadavg.h presence... no
checking for sys/loadavg.h... no
checking whether getloadavg is declared... yes
checking for library containing gethostbyname... (cached) none required
checking for gethostbyname... (cached) yes
checking for library containing inet_ntop... (cached) none required
checking whether inet_ntop is declared... (cached) yes
checking whether the compiler generally respects inline... yes
checking whether langinfo.h defines CODESET... yes
checking whether langinfo.h defines ERA... yes
checking whether nl_langinfo is declared without a macro... yes
checking whether locale.h conforms to POSIX:2001... yes
checking whether locale.h defines locale_t... yes
checking whether duplocale is declared without a macro... yes
checking for GNU libc compatible malloc... (cached) yes
checking whether NAN macro works... yes
checking whether HUGE_VAL works... yes
checking whether acosl is declared without a macro... yes
checking whether asinl is declared without a macro... yes
checking whether atanl is declared without a macro... yes
checking whether ceilf is declared without a macro... yes
checking whether ceill is declared without a macro... yes
checking whether cosl is declared without a macro... yes
checking whether expl is declared without a macro... yes
checking whether floorf is declared without a macro... yes
checking whether floorl is declared without a macro... yes
checking whether frexpl is declared without a macro... yes
checking whether ldexpl is declared without a macro... yes
checking whether logb is declared without a macro... yes
checking whether logl is declared without a macro... yes
checking whether round is declared without a macro... yes
checking whether roundf is declared without a macro... yes
checking whether roundl is declared without a macro... yes
checking whether sinl is declared without a macro... yes
checking whether sqrtl is declared without a macro... yes
checking whether tanl is declared without a macro... yes
checking whether trunc is declared without a macro... yes
checking whether truncf is declared without a macro... yes
checking whether truncl is declared without a macro... yes
checking whether mbrtowc handles incomplete characters... yes
checking whether mbrtowc works as well as mbtowc... yes
checking whether mbrtowc handles a NULL string argument... yes
checking whether mbrtowc has a correct return value... yes
checking whether mbrtowc returns 0 when parsing a NUL character... yes
checking whether mbrtowc handles incomplete characters... (cached) yes
checking whether mbrtowc works as well as mbtowc... (cached) yes
checking for working mktime... yes
checking for listmntent... no
checking for getmntinfo... no
checking for sys/ucred.h... no
checking for sys/mount.h... (cached) yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking for sys/fs_types.h... (cached) no
checking for struct fsstat.f_fstypename... no
checking for library containing getmntent... none required
checking for getmntent... yes
checking for listmntent of Cray/Unicos-9... no
checking for mntctl function and struct vmount... no
checking for one-argument getmntent function... yes
checking sys/mntent.h usability... no
checking sys/mntent.h presence... no
checking for sys/mntent.h... no
checking for struct statfs.f_fstypename... no
checking whether getaddrinfo is declared without a macro... (cached) yes
checking whether freeaddrinfo is declared without a macro... (cached) yes
checking whether gai_strerror is declared without a macro... (cached) yes
checking whether getnameinfo is declared without a macro... (cached) yes
checking whether <netinet/in.h> is self-contained... yes
checking whether open recognizes a trailing slash... yes
checking for working re_compile_pattern... yes
checking for library containing getservbyname... (cached) none required
checking for getservbyname... (cached) yes
checking for SIZE_MAX... yes
checking for snprintf... (cached) yes
checking whether snprintf respects a size of 1... yes
checking for library containing setsockopt... none needed
checking for socklen_t... yes
checking for ssize_t... (cached) yes
checking whether stat handles trailing slashes on directories... yes
checking whether stat handles trailing slashes on files... yes
checking whether NULL can be used in arbitrary expressions... (cached) yes
checking whether stdint.h conforms to C99... yes
checking whether dprintf is declared without a macro... yes
checking whether fpurge is declared without a macro... no
checking whether fseeko is declared without a macro... yes
checking whether ftello is declared without a macro... yes
checking whether getdelim is declared without a macro... yes
checking whether getline is declared without a macro... yes
checking whether popen is declared without a macro... yes
checking whether renameat is declared without a macro... yes
checking whether snprintf is declared without a macro... yes
checking whether tmpfile is declared without a macro... yes
checking whether vdprintf is declared without a macro... yes
checking whether vsnprintf is declared without a macro... yes
checking for random.h... no
checking for struct random_data... yes
checking whether atoll is declared without a macro... yes
checking whether canonicalize_file_name is declared without a macro... yes
checking whether getloadavg is declared without a macro... yes
checking whether getsubopt is declared without a macro... yes
checking whether grantpt is declared without a macro... yes
checking whether mkdtemp is declared without a macro... yes
checking whether mkostemp is declared without a macro... yes
checking whether mkostemps is declared without a macro... yes
checking whether mkstemp is declared without a macro... yes
checking whether mkstemps is declared without a macro... yes
checking whether ptsname is declared without a macro... yes
checking whether random_r is declared without a macro... yes
checking whether initstat_r is declared without a macro... no
checking whether srandom_r is declared without a macro... yes
checking whether setstate_r is declared without a macro... yes
checking whether realpath is declared without a macro... yes
checking whether rpmatch is declared without a macro... yes
checking whether setenv is declared without a macro... yes
checking whether strtod is declared without a macro... yes
checking whether strtoll is declared without a macro... yes
checking whether strtoull is declared without a macro... yes
checking whether unlockpt is declared without a macro... yes
checking whether unsetenv is declared without a macro... yes
checking for working strndup... yes
checking for working strnlen... yes
checking for strsep... yes
checking whether <sys/socket.h> is self-contained... (cached) yes
checking for shutdown... (cached) yes
checking whether <sys/socket.h> defines the SHUT_* macros... (cached) yes
checking for struct sockaddr_storage... (cached) yes
checking for sa_family_t... (cached) yes
checking whether socket is declared without a macro... (cached) no
checking whether connect is declared without a macro... (cached) no
checking whether accept is declared without a macro... (cached) no
checking whether bind is declared without a macro... (cached) no
checking whether getpeername is declared without a macro... (cached) no
checking whether getsockname is declared without a macro... (cached) no
checking whether getsockopt is declared without a macro... (cached) no
checking whether listen is declared without a macro... (cached) no
checking whether recv is declared without a macro... (cached) no
checking whether send is declared without a macro... (cached) no
checking whether recvfrom is declared without a macro... (cached) no
checking whether sendto is declared without a macro... (cached) no
checking whether setsockopt is declared without a macro... (cached) no
checking whether shutdown is declared without a macro... (cached) no
checking whether accept4 is declared without a macro... (cached) no
checking for nlink_t... yes
checking whether fchmodat is declared without a macro... yes
checking whether fstatat is declared without a macro... yes
checking whether futimens is declared without a macro... yes
checking whether lchmod is declared without a macro... yes
checking whether lstat is declared without a macro... yes
checking whether mkdirat is declared without a macro... yes
checking whether mkfifo is declared without a macro... yes
checking whether mkfifoat is declared without a macro... yes
checking whether mknod is declared without a macro... yes
checking whether mknodat is declared without a macro... yes
checking whether stat is declared without a macro... yes
checking whether utimensat is declared without a macro... yes
checking whether localtime_r is compatible with its POSIX signature... yes
checking whether chown is declared without a macro... yes
checking whether dup2 is declared without a macro... yes
checking whether dup3 is declared without a macro... yes
checking whether environ is declared without a macro... yes
checking whether euidaccess is declared without a macro... yes
checking whether faccessat is declared without a macro... yes
checking whether fchdir is declared without a macro... yes
checking whether fchownat is declared without a macro... yes
checking whether fsync is declared without a macro... yes
checking whether ftruncate is declared without a macro... yes
checking whether getcwd is declared without a macro... yes
checking whether getdomainname is declared without a macro... yes
checking whether getdtablesize is declared without a macro... yes
checking whether getgroups is declared without a macro... yes
checking whether gethostname is declared without a macro... yes
checking whether getlogin is declared without a macro... yes
checking whether getlogin_r is declared without a macro... yes
checking whether getpagesize is declared without a macro... yes
checking whether getusershell is declared without a macro... yes
checking whether setusershell is declared without a macro... yes
checking whether endusershell is declared without a macro... yes
checking whether lchown is declared without a macro... yes
checking whether link is declared without a macro... yes
checking whether linkat is declared without a macro... yes
checking whether lseek is declared without a macro... yes
checking whether pipe2 is declared without a macro... yes
checking whether pread is declared without a macro... yes
checking whether pwrite is declared without a macro... yes
checking whether readlink is declared without a macro... yes
checking whether readlinkat is declared without a macro... yes
checking whether rmdir is declared without a macro... yes
checking whether sleep is declared without a macro... yes
checking whether symlink is declared without a macro... yes
checking whether symlinkat is declared without a macro... yes
checking whether ttyname_r is declared without a macro... yes
checking whether unlink is declared without a macro... yes
checking whether unlinkat is declared without a macro... yes
checking whether usleep is declared without a macro... yes
checking for unsetenv... yes
checking for unsetenv() return type... int
checking whether unsetenv works on duplicates... yes
checking for ptrdiff_t... yes
checking for vasprintf... yes
checking for vsnprintf... yes
checking whether snprintf respects a size of 1... (cached) yes
checking whether btowc is declared without a macro... yes
checking whether wctob is declared without a macro... yes
checking whether mbsinit is declared without a macro... yes
checking whether mbrtowc is declared without a macro... yes
checking whether mbrlen is declared without a macro... yes
checking whether mbsrtowcs is declared without a macro... yes
checking whether mbsnrtowcs is declared without a macro... yes
checking whether wcrtomb is declared without a macro... yes
checking whether wcsrtombs is declared without a macro... yes
checking whether wcsnrtombs is declared without a macro... yes
checking whether wcwidth is declared without a macro... yes
checking whether wcrtomb return value is correct... yes
checking whether iswcntrl works... yes
configure: creating ./config.status
config.status: creating gl/Makefile
config.status: creating Makefile
config.status: creating tap/Makefile
config.status: creating lib/Makefile
config.status: creating plugins/Makefile
config.status: creating lib/tests/Makefile
config.status: creating plugins-root/Makefile
config.status: creating plugins-scripts/Makefile
config.status: creating plugins-scripts/subst
config.status: creating plugins-scripts/utils.pm
config.status: creating plugins-scripts/utils.sh
config.status: creating perlmods/Makefile
config.status: creating command.cfg
config.status: creating test.pl
config.status: creating pkg/solaris/pkginfo
config.status: creating po/Makefile.in
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
config.status: executing libtool commands
config.status: executing po-directories commands
config.status: creating po/POTFILES
--with-apt-get-command:
--with-ping6-command: /bin/ping6 -n -U -w %d -c %d %s
--with-ping-command: /bin/ping -n -U -w %d -c %d %s
--with-ipv6: yes
--with-mysql: no
--with-openssl: yes
--with-gnutls: no
--enable-extra-opts: no
--with-perl: /usr/bin/perl
--enable-perl-modules: no
--with-cgiurl: /nagios/cgi-bin
--with-trusted-path: /bin:/sbin:/usr/bin:/usr/sbin
--enable-libtap: no
Below is the output from --help. I didn't use any configure options as I was following the quick start guide. As I stated above I'm a noob when it comes to linux so I just did what the internet told me :)
Thanks
`configure' configures nagios-plugins 1.4.15 to adapt to many kinds of systems.
Usage: ./configure [OPTION]... [VAR=VALUE]...
To assign environment variables (e.g., CC, CFLAGS...), specify them as
VAR=VALUE. See below for descriptions of some of the useful variables.
Defaults for the options are specified in brackets.
Configuration:
-h, --help display this help and exit
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
-q, --quiet, --silent do not print `checking...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for `--cache-file=config.cache'
-n, --no-create do not create output files
--srcdir=DIR find the sources in DIR [configure dir or `..']
Installation directories:
--prefix=PREFIX install architecture-independent files in PREFIX
[/usr/local/nagios]
--exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
[PREFIX]
By default, `make install' will install all the files in
`/usr/local/nagios/bin', `/usr/local/nagios/lib' etc. You can specify
an installation prefix other than `/usr/local/nagios' using `--prefix',
for instance `--prefix=$HOME'.
For better control, use the options below.
Fine tuning of the installation directories:
--bindir=DIR user executables [EPREFIX/bin]
--sbindir=DIR system admin executables [EPREFIX/sbin]
--libexecdir=DIR program executables [EPREFIX/libexec]
--sysconfdir=DIR read-only single-machine data [PREFIX/etc]
--sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
--localstatedir=DIR modifiable single-machine data [PREFIX/var]
--libdir=DIR object code libraries [EPREFIX/lib]
--includedir=DIR C header files [PREFIX/include]
--oldincludedir=DIR C header files for non-gcc [/usr/include]
--datarootdir=DIR read-only arch.-independent data root [PREFIX/share]
--datadir=DIR read-only architecture-independent data [DATAROOTDIR]
--infodir=DIR info documentation [DATAROOTDIR/info]
--localedir=DIR locale-dependent data [DATAROOTDIR/locale]
--mandir=DIR man documentation [DATAROOTDIR/man]
--docdir=DIR documentation root [DATAROOTDIR/doc/nagios-plugins]
--htmldir=DIR html documentation [DOCDIR]
--dvidir=DIR dvi documentation [DOCDIR]
--pdfdir=DIR pdf documentation [DOCDIR]
--psdir=DIR ps documentation [DOCDIR]
Program names:
--program-prefix=PREFIX prepend PREFIX to installed program names
--program-suffix=SUFFIX append SUFFIX to installed program names
--program-transform-name=PROGRAM run sed PROGRAM on installed program names
System types:
--build=BUILD configure for building on BUILD [guessed]
--host=HOST cross-compile to build programs to run on HOST [BUILD]
Optional Features:
--disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
--disable-dependency-tracking speeds up one-time build
--enable-dependency-tracking do not reject slow dependency extractors
--enable-shared[=PKGS] build shared libraries [default=yes]
--enable-static[=PKGS] build static libraries [default=yes]
--enable-fast-install[=PKGS]
optimize for fast installation [default=yes]
--disable-libtool-lock avoid locking (might break parallel builds)
--disable-largefile omit support for large files
--enable-libtap Enable built-in libtap for unit-testing (default:
autodetect system library).
--enable-extra-opts Enables parsing of plugins ini config files for
extra options (default: no)
--disable-nls do not use Native Language Support
--disable-rpath do not hardcode runtime library paths
--enable-redhat-pthread-workaround
force Redhat patch to be applied (default: test
system)
--enable-perl-modules Enables installation of Nagios::Plugin and its
dependencies (default: no)
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
--without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
--with-nagios-user=USER Installs executables with this user. Defaults to install user
--with-nagios-group=GROUP Installs executables with this group. Defaults to install user
--without-world-permissions Installs executables without world permissions
--with-pic try to use only PIC/non-PIC objects [default=use
both]
--with-gnu-ld assume the C compiler uses GNU ld [default=no]
--with-cgiurl=DIR sets URL for cgi programs
--with-trusted-path=PATH sets trusted path for executables called by scripts (default=/bin:/sbin:/usr/bin:/usr/sbin)
--with-perl=PATH sets path to perl executable
--with-openssl=DIR path to openssl installation
--with-gnutls=PATH path to gnutls installation root
--with-pgsql=DIR sets path to pgsql installation
--with-mysql=DIR Locates mysql libraries. Expects
DIR/bin/mysql_config. Default to search for
mysql_config in PATH
--with-ipv6 support IPv6 [default=check]
--with-ps-command=PATH Verbatim command to execute for ps
--with-ps-format=FORMAT Format string for scanning ps output
--with-ps-cols=NUM Number of columns in ps command
--with-ps-varlist=LIST Variable list for sscanf of 'ps' output
--with-ping-command=SYNTAX sets syntax for ICMP ping
--with-ping6-command=SYNTAX sets syntax for ICMPv6 ping
--with-nslookup-command=PATH sets path to nslookup executable
--with-uptime-command=PATH sets path to uptime
--with-rpcinfo-command=PATH sets path to rpcinfo
--with-smbclient-command=PATH sets path to smbclient
--with-snmpget-command=PATH Path to snmpget command
--with-snmpgetnext-command=PATH Path to snmpgetnext command
--with-qstat-command=PATH Path to qstat command
--with-fping-command=PATH Path to fping command
--with-ssh-command=PATH sets path for ssh
--with-mailq-command=PATH sets path to mailq
--with-proc-meminfo=PATH path to /proc/meminfo or equivalent
--with-dig-command=PATH Path to dig command
--with-apt-get-command=PATH Path to apt-get command
--with-gnu-ld assume the C compiler uses GNU ld default=no
--with-libiconv-prefix[=DIR] search for libiconv in DIR/include and DIR/lib
--without-libiconv-prefix don't search for libiconv in includedir and libdir
--with-libintl-prefix[=DIR] search for libintl in DIR/include and DIR/lib
--without-libintl-prefix don't search for libintl in includedir and libdir
--without-included-regex
don't compile regex; this is the default on systems
with recent-enough versions of the GNU C Library
(use with caution on other systems).
Some influential environment variables:
CC C compiler command
CFLAGS C compiler flags
LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
nonstandard directory <lib dir>
LIBS libraries to pass to the linker, e.g. -l<library>
CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
you have headers in a nonstandard directory <include dir>
CPP C preprocessor
Use these variables to override the choices made by `configure' or to help
it to find libraries and programs with nonstandard names/locations.
as for more information.....
here is a A-Z list of ALL the packages installed on my system.
abrt-1.1.13-2.fc14.i686
abrt-1.1.14-1.fc14.i686
abrt-addon-ccpp-1.1.13-2.fc14.i686
abrt-addon-ccpp-1.1.14-1.fc14.i686
abrt-addon-kerneloops-1.1.13-2.fc14.i686
abrt-addon-kerneloops-1.1.14-1.fc14.i686
abrt-addon-python-1.1.13-2.fc14.i686
abrt-addon-python-1.1.14-1.fc14.i686
abrt-desktop-1.1.14-1.fc14.i686
abrt-gui-1.1.13-2.fc14.i686
abrt-gui-1.1.14-1.fc14.i686
abrt-libs-1.1.13-2.fc14.i686
abrt-libs-1.1.14-1.fc14.i686
abrt-plugin-bugzilla-1.1.13-2.fc14.i686
abrt-plugin-bugzilla-1.1.14-1.fc14.i686
abrt-plugin-logger-1.1.13-2.fc14.i686
abrt-plugin-logger-1.1.14-1.fc14.i686
abrt-plugin-runapp-1.1.13-2.fc14.i686
abrt-plugin-runapp-1.1.14-1.fc14.i686
acl-2.2.49-8.fc14.i686
alsa-firmware-1.0.23-1.fc14.noarch
alsa-lib-1.0.23-1.fc14.i686
alsa-lib-1.0.23-2.fc14.i686
alsa-plugins-pulseaudio-1.0.22-1.fc13.i686
alsa-tools-firmware-1.0.23-1.fc14.i686
alsa-utils-1.0.23-3.fc14.i686
anaconda-14.22-1.fc14.i686
anaconda-yum-plugins-1.0-5.fc12.noarch
anthy-9100h-15.fc14.i686
apr-1.3.9-3.fc13.i686
apr-util-1.3.10-1.fc14.i686
apr-util-1.3.9-3.fc13.i686
apr-util-ldap-1.3.10-1.fc14.i686
apr-util-ldap-1.3.9-3.fc13.i686
apt-0.5.15lorg3.95-0.git416.6.fc14.1.i686
ar9170-firmware-2009.05.28-2.fc13.noarch
at-3.1.12-5.fc14.i686
atk-1.30.0-5.fc14.i686
atk-1.32.0-1.fc14.i686
atkmm-2.22.0-1.fc14.i686
atmel-firmware-1.3-7.fc13.noarch
at-spi-1.31.1-3.fc14.i686
at-spi-1.32.0-2.fc14.i686
at-spi2-atk-0.3.91.1-1.fc14.i686
at-spi2-atk-0.4.0-1.fc14.i686
at-spi2-core-0.3.4-1.fc14.i686
at-spi2-core-0.4.0-1.fc14.i686
at-spi-python-1.32.0-2.fc14.i686
attr-2.4.44-5.fc14.i686
attr-2.4.44-6.fc14.i686
audit-2.0.4-4.fc14.i686
audit-libs-2.0.4-4.fc14.i686
audit-libs-python-2.0.4-4.fc14.i686
authconfig-6.1.11-1.fc14.i686
authconfig-6.1.9-1.fc14.i686
authconfig-gtk-6.1.11-1.fc14.i686
avahi-0.6.27-2.fc14.i686
avahi-autoipd-0.6.27-2.fc14.i686
avahi-glib-0.6.27-2.fc14.i686
avahi-gobject-0.6.27-2.fc14.i686
avahi-libs-0.6.27-2.fc14.i686
avahi-ui-0.6.27-2.fc14.i686
b43-fwcutter-013-2.fc14.i686
b43-openfwwf-5.2-5.fc14.noarch
basesystem-10.0-3.noarch
bash-4.1.7-3.fc14.i686
bc-1.06.95-1.fc12.i686
bc-1.06.95-2.fc14.i686
bind-libs-9.7.2-2.P2.fc14.i686
bind-libs-9.7.2-5.P3.fc14.i686
bind-utils-9.7.2-2.P2.fc14.i686
bind-utils-9.7.2-5.P3.fc14.i686
binutils-2.20.51.0.7-6.fc14.i686
bluez-4.71-5.fc14.i686
bluez-4.77-1.fc14.i686
bluez-cups-4.71-5.fc14.i686
bluez-cups-4.77-1.fc14.i686
bluez-libs-4.71-5.fc14.i686
bluez-libs-4.77-1.fc14.i686
boost-filesystem-1.44.0-1.fc14.i686
boost-filesystem-1.44.0-7.fc14.i686
boost-system-1.44.0-1.fc14.i686
boost-system-1.44.0-7.fc14.i686
brasero-2.32.0-1.fc14.i686
brasero-libs-2.32.0-1.fc14.i686
brasero-nautilus-2.32.0-1.fc14.i686
bzip2-1.0.6-1.fc14.1.i686
bzip2-libs-1.0.6-1.fc14.1.i686
c2050-0.3b-3.fc12.i686
c2070-0.99-6.fc12.i686
ca-certificates-2010.63-3.fc14.noarch
cairo-1.10.0-1.fc14.i686
cairo-1.10.2-1.fc14.i686
cairomm-1.9.2-1.fc14.i686
c-ares-1.7.3-1.fc14.i686
caribou-0.1.5-2.fc14.noarch
cdparanoia-10.2-9.fc13.i686
cdparanoia-libs-10.2-9.fc13.i686
cdrdao-1.2.3-7.fc14.i686
celt-0.8.1-1.fc14.1.i686
celt-0.8.1-1.fc14.i686
checkpolicy-2.0.22-1.fc14.i686
checkpolicy-2.0.23-2.fc14.i686
cheese-2.32.0-1.fc14.i686
cheese-libs-2.32.0-1.fc14.i686
chkconfig-1.3.47-1.fc14.i686
chkconfig-1.3.49-1.fc14.i686
cifs-utils-4.6-1.fc14.i686
cifs-utils-4.8.1-1.fc14.i686
cjet-0.8.9-9.fc12.i686
cloog-ppl-0.15.7-2.fc14.i686
clutter-1.2.14-1.fc14.1.i686
clutter-1.2.14-1.fc14.i686
color-filesystem-1-7.noarch
compiz-0.8.6-3.fc14.i686
compiz-0.8.6-6.fc14.i686
compiz-gnome-0.8.6-3.fc14.i686
compiz-gnome-0.8.6-6.fc14.i686
comps-extras-20-1.fc13.noarch
ConsoleKit-0.4.2-2.fc14.1.i686
ConsoleKit-0.4.2-3.fc14.i686
ConsoleKit-libs-0.4.2-2.fc14.1.i686
ConsoleKit-libs-0.4.2-3.fc14.i686
ConsoleKit-x11-0.4.2-2.fc14.1.i686
ConsoleKit-x11-0.4.2-3.fc14.i686
control-center-2.32.0-1.fc14.i686
control-center-filesystem-2.32.0-1.fc14.i686
coreutils-8.5-6.fc14.i686
coreutils-8.5-7.fc14.i686
coreutils-libs-8.5-6.fc14.i686
coreutils-libs-8.5-7.fc14.i686
cpio-2.11-2.fc14.i686
cpp-4.5.1-4.fc14.i686
cpuspeed-1.5-14.fc14.i686
cracklib-2.8.16-4.fc14.i686
cracklib-dicts-2.8.16-4.fc14.i686
cracklib-python-2.8.16-4.fc14.i686
crda-1.1.1_2009.11.25-3.fc14.i686
crda-1.1.1_2010.11.22-1.fc14.i686
createrepo-0.9.8-5.fc14.noarch
cronie-1.4.5-2.fc14.i686
cronie-1.4.5-4.fc14.i686
cronie-anacron-1.4.5-2.fc14.i686
cronie-anacron-1.4.5-4.fc14.i686
crontabs-1.10-33.fc14.noarch
crontabs-1.11-1.20101115git.fc14.noarch
cryptopp-5.6.1-1.fc14.i686
cryptopp-5.6.1-3.fc14.i686
cryptsetup-luks-1.1.3-1.fc14.i686
cryptsetup-luks-libs-1.1.3-1.fc14.i686
cups-1.4.4-10.fc14.i686
cups-1.4.6-1.fc14.i686
cups-libs-1.4.4-10.fc14.i686
cups-libs-1.4.6-1.fc14.i686
cups-pk-helper-0.0.4-13.fc14.i686
curl-7.21.0-5.fc14.i686
curl-7.21.0-6.fc14.i686
cyrus-sasl-2.1.23-12.fc14.i686
cyrus-sasl-devel-2.1.23-12.fc14.i686
cyrus-sasl-gssapi-2.1.23-12.fc14.i686
cyrus-sasl-lib-2.1.23-12.fc14.i686
cyrus-sasl-md5-2.1.23-12.fc14.i686
cyrus-sasl-plain-2.1.23-12.fc14.i686
dash-0.5.6-2.fc14.i686
db4-4.8.30-2.fc14.i686
db4-utils-4.8.30-2.fc14.i686
dbus-1.4.0-1.fc14.i686
dbus-1.4.0-2.fc14.i686
dbus-c++-0.5.0-0.11.20090203git13281b3.fc13.i686
dbus-glib-0.86-4.fc14.i686
dbus-libs-1.4.0-1.fc14.i686
dbus-libs-1.4.0-2.fc14.i686
dbus-python-0.83.0-7.fc14.i686
dbus-x11-1.4.0-1.fc14.i686
dbus-x11-1.4.0-2.fc14.i686
dconf-0.5.1-1.fc14.i686
deja-dup-15.3-2.fc14.i686
deja-dup-16.1-2.fc14.i686
dejavu-fonts-common-2.32-1.fc14.noarch
dejavu-sans-fonts-2.32-1.fc14.noarch
dejavu-sans-mono-fonts-2.32-1.fc14.noarch
dejavu-serif-fonts-2.32-1.fc14.noarch
deltarpm-3.6-0.2.20100708git.fc14.i686
desktop-effects-0.8.7-2.fc14.i686
desktop-file-utils-0.16-1.fc14.i686
device-mapper-1.02.54-3.fc14.i686
device-mapper-event-1.02.54-3.fc14.i686
device-mapper-event-libs-1.02.54-3.fc14.i686
device-mapper-libs-1.02.54-3.fc14.i686
device-mapper-multipath-0.4.9-14.fc13.i686
device-mapper-multipath-libs-0.4.9-14.fc13.i686
dhclient-4.2.0-18.P2.fc14.i686
dhclient-4.2.0-6.fc14.i686
dialog-1.1-11.20100428.fc14.i686
diffutils-2.8.1-29.fc14.i686
dirac-libs-1.0.2-3.fc12.i686
dirac-libs-1.0.2-4.fc14.i686
distcache-1.4.5-21.i686
dmidecode-2.10-2.fc14.i686
dmidecode-2.11-2.fc14.i686
dmraid-1.0.0.rc16-12.fc13.i686
dmraid-events-1.0.0.rc16-12.fc13.i686
dmz-cursor-themes-0.4-3.fc14.noarch
dnsmasq-2.52-1.fc13.i686
docbook-dtds-1.0-53.fc14.noarch
dosfstools-3.0.9-3.fc14.i686
dosfstools-3.0.9-4.fc14.i686
dpkg-1.15.5.6-6.fc14.i686
dracut-006-3.fc14.noarch
dracut-006-6.fc14.noarch
dump-0.4-0.8.b43.fc14.i686
duplicity-0.6.09-1.fc14.1.i686
duplicity-0.6.11-1.fc14.i686
dvb-apps-1.1.1-22.fc14.i686
dvd+rw-tools-7.1-5.fc14.i686
e2fsprogs-1.41.12-5.fc14.i686
e2fsprogs-1.41.12-6.fc14.i686
e2fsprogs-libs-1.41.12-5.fc14.i686
e2fsprogs-libs-1.41.12-6.fc14.i686
ed-1.4-2.fc14.i686
efibootmgr-0.5.4-9.fc14.i686
eject-2.1.5-20.fc14.i686
elfutils-0.149-1.fc14.i686
elfutils-0.151-1.fc14.i686
elfutils-devel-0.151-1.fc14.i686
elfutils-libelf-0.149-1.fc14.i686
elfutils-libelf-0.151-1.fc14.i686
elfutils-libelf-devel-0.151-1.fc14.i686
elfutils-libs-0.149-1.fc14.i686
elfutils-libs-0.151-1.fc14.i686
empathy-2.32.0.1-2.fc14.i686
empathy-2.32.2-1.fc14.i686
enca-1.13-1.fc14.i686
enchant-1.6.0-1.fc14.i686
eog-2.32.0-1.fc14.i686
eog-2.32.0-3.fc14.i686
evince-2.32.0-1.fc14.i686
evince-2.32.0-3.fc14.i686
evince-libs-2.32.0-1.fc14.i686
evince-libs-2.32.0-3.fc14.i686
evince-nautilus-2.32.0-1.fc14.i686
evince-nautilus-2.32.0-3.fc14.i686
evolution-2.32.0-2.fc14.i686
evolution-2.32.1-1.fc14.i686
evolution-data-server-2.32.0-1.fc14.i686
evolution-data-server-2.32.1-1.fc14.i686
exempi-2.1.1-1.fc13.i686
exiv2-libs-0.20-1.fc14.i686
expat-2.0.1-10.fc13.i686
farsight2-0.0.21-2.fc14.i686
farsight2-python-0.0.21-2.fc14.i686
fcoe-utils-1.0.14-2.fc14.i686
fcoe-utils-1.0.14-3.fc14.i686
fedora-bookmarks-14-1.noarch
fedora-gnome-theme-13.4-2.fc14.noarch
fedora-icon-theme-1.0.0-7.fc13.noarch
fedora-logos-14.0.1-500.fc14.noarch
fedora-package-config-apt-13.89-7.noarch
fedora-release-14-1.noarch
fedora-release-notes-14.0.3-1.fc14.noarch
fedora-release-notes-14.1.2-1.fc14.noarch
fedora-screensaver-theme-1.0.0-5.fc12.noarch
festival-1.96-16.fc13.i686
festival-lib-1.96-16.fc13.i686
festival-speechtools-libs-1.2.96-16.fc13.i686
festvox-slt-arctic-hts-0.20061229-16.fc13.noarch
fftw-3.2.2-4.fc13.i686
file-5.04-15.fc14.i686
file-devel-5.04-15.fc14.i686
file-libs-5.04-15.fc14.i686
file-roller-2.32.0-2.fc14.i686
filesystem-2.4.35-1.fc14.i686
findutils-4.5.9-2.fc14.i686
fipscheck-1.2.0-4.fc13.i686
fipscheck-lib-1.2.0-4.fc13.i686
firefox-3.6.13-1.fc14.i686
firstboot-1.113-4.fc14.i686
flac-1.2.1-6.fc12.i686
folks-0.1.16-1.fc14.1.i686
folks-0.1.16-1.fc14.i686
fontconfig-2.8.0-2.fc14.i686
fontconfig-devel-2.8.0-2.fc14.i686
fontpackages-filesystem-1.44-1.fc14.noarch
foomatic-filters-4.0.5-1.fc14.i686
fprintd-0.2.0-1.fc14.i686
fprintd-0.2.0-2.fc14.i686
fprintd-pam-0.2.0-1.fc14.i686
fprintd-pam-0.2.0-2.fc14.i686
freetype-2.4.2-4.fc14.i686
freetype-devel-2.4.2-4.fc14.i686
ftp-0.17-51.fc12.i686
fuse-2.8.5-2.fc14.i686
fuse-libs-2.8.4-1.fc14.i686
fuse-libs-2.8.5-2.fc14.i686
fxload-2002_04_11-9.fc12.i686
gamin-0.1.10-8.fc14.i686
gawk-3.1.8-1.fc14.i686
gawk-3.1.8-3.fc14.i686
gcalctool-5.32.0-1.fc14.i686
gcc-4.5.1-4.fc14.i686
GConf2-2.31.91-1.fc14.i686
GConf2-gtk-2.31.91-1.fc14.i686
gconfmm26-2.28.2-1.fc14.i686
gd-2.0.35-11.fc13.i686
gdb-7.2-16.fc14.i686
gdb-7.2-36.fc14.i686
gdbm-1.8.3-6.fc14.i686
gdbm-1.8.3-8.fc14.i686
gd-devel-2.0.35-11.fc13.i686
gdk-pixbuf2-2.22.0-1.fc14.i686
gdm-2.32.0-1.fc14.i686
gdm-plugin-fingerprint-2.32.0-1.fc14.i686
gdm-user-switch-applet-2.32.0-1.fc14.i686
gedit-2.30.4-1.fc14.i686
genisoimage-1.1.10-2.fc14.i686
genisoimage-1.1.11-1.fc14.i686
geoclue-0.12.0-1.fc14.i686
geoclue-0.12.0-3.fc14.i686
gftp-2.0.19-4.fc14.i686
ghostscript-8.71-16.fc14.i686
ghostscript-cups-8.71-16.fc14.i686
ghostscript-fonts-5.50-23.fc12.noarch
glew-1.5.4-1.fc14.i686
glew-1.5.7-1.fc14.i686
glib2-2.26.0-2.fc14.i686
glibc-2.12.90-21.i686
glibc-common-2.12.90-21.i686
glibc-devel-2.12.90-21.i686
glibc-headers-2.12.90-21.i686
glibmm24-2.24.2-1.fc14.1.i686
glx-utils-7.9-1.fc14.i686
glx-utils-7.9-5.fc14.i686
gmime-2.5.1-1.fc13.i686
gmp-4.3.1-7.fc14.i686
gnome-applets-2.32.0-1.fc14.i686
gnome-applets-2.32.0-3.fc14.i686
gnome-backgrounds-2.32.0-1.fc14.noarch
gnome-bluetooth-2.32.0-1.fc14.i686
gnome-bluetooth-libs-2.32.0-1.fc14.i686
gnome-color-manager-2.32.0-2.fc14.i686
gnome-desktop-2.32.0-1.fc14.i686
gnome-desktop-2.32.0-2.fc14.i686
gnome-disk-utility-2.32.0-1.fc14.i686
gnome-disk-utility-libs-2.32.0-1.fc14.i686
gnome-disk-utility-ui-libs-2.32.0-1.fc14.i686
gnome-doc-utils-stylesheets-0.20.1-3.fc14.noarch
gnome-doc-utils-stylesheets-0.20.2-1.fc14.noarch
gnome-dvb-daemon-0.1.20-4.fc14.i686
gnome-dvb-daemon-0.1.21-1.fc14.i686
gnome-games-2.32.0-3.fc14.i686
gnome-icon-theme-2.31.0-1.fc14.noarch
gnome-icon-theme-extras-2.30.1-2.fc14.noarch
gnome-icon-theme-symbolic-2.31.0-1.fc14.noarch
gnome-js-common-0.1.2-3.fc14.noarch
gnome-keyring-2.32.0-1.fc14.i686
gnome-keyring-2.32.1-1.fc14.i686
gnome-keyring-pam-2.32.0-1.fc14.i686
gnome-keyring-pam-2.32.1-1.fc14.i686
gnome-mag-0.16.1-1.fc14.i686
gnome-mag-0.16.2-1.fc14.i686
gnome-media-2.32.0-1.fc14.i686
gnome-media-2.32.0-2.fc14.i686
gnome-media-libs-2.32.0-1.fc14.i686
gnome-media-libs-2.32.0-2.fc14.i686
gnome-menus-2.30.4-1.fc14.i686
gnome-packagekit-2.32.0-2.fc14.i686
gnome-panel-2.32.0.2-2.fc14.i686
gnome-panel-libs-2.32.0.2-2.fc14.i686
gnome-pilot-2.32.0-1.fc14.i686
gnome-power-manager-2.32.0-3.fc14.i686
gnome-python2-2.28.1-3.fc14.i686
gnome-python2-applet-2.32.0-1.fc14.i686
gnome-python2-bonobo-2.28.1-3.fc14.i686
gnome-python2-canvas-2.28.1-3.fc14.i686
gnome-python2-desktop-2.32.0-1.fc14.i686
gnome-python2-extras-2.25.3-23.fc14.1.i686
gnome-python2-extras-2.25.3-26.fc14.1.i686
gnome-python2-gconf-2.28.1-3.fc14.i686
gnome-python2-gnome-2.28.1-3.fc14.i686
gnome-python2-gnomekeyring-2.32.0-1.fc14.i686
gnome-python2-gnomevfs-2.28.1-3.fc14.i686
gnome-python2-gtkhtml2-2.25.3-23.fc14.1.i686
gnome-python2-gtkhtml2-2.25.3-26.fc14.1.i686
gnome-python2-libegg-2.25.3-23.fc14.1.i686
gnome-python2-libegg-2.25.3-26.fc14.1.i686
gnome-python2-libwnck-2.32.0-1.fc14.i686
gnome-screensaver-2.30.2-2.fc14.i686
gnome-session-2.32.0-1.fc14.i686
gnome-session-xsession-2.32.0-1.fc14.i686
gnome-settings-daemon-2.32.0-1.fc14.i686
gnome-settings-daemon-2.32.1-1.fc14.i686
gnome-speech-0.4.25-3.fc12.i686
gnome-system-monitor-2.28.2-1.fc14.i686
gnome-terminal-2.32.0-1.fc14.i686
gnome-themes-2.32.0-1.fc14.noarch
gnome-user-docs-2.32.0-1.fc14.noarch
gnome-user-share-2.30.0-7.fc14.i686
gnome-user-share-2.30.1-1.fc14.i686
gnome-utils-2.32.0-2.fc14.i686
gnome-utils-libs-2.32.0-2.fc14.i686
gnome-vfs2-2.24.4-1.fc14.i686
gnote-0.7.2-2.fc14.i686
gnote-0.7.3-4.fc14.i686
gnupg-1.4.10-2.fc14.i686
gnupg-1.4.11-2.fc14.i686
gnupg2-2.0.16-3.fc14.1.i686
gnutls-2.8.6-2.fc14.i686
gobject-introspection-0.9.3-1.fc14.i686
gok-2.30.0-1.fc14.i686
gpgme-1.2.0-3.fc14.i686
gpg-pubkey-97a1071f-4c49d6fe
grep-2.7-1.fc14.1.i686
groff-1.20.1-2.fc14.i686
grub-0.97-66.fc14.i686
grubby-7.0.16-1.fc14.i686
gsm-1.0.13-2.fc12.i686
gssdp-0.8.0-1.fc14.1.i686
gssdp-0.8.2-1.fc14.i686
gstreamer-0.10.30-1.fc14.i686
gstreamer-0.10.31-1.fc14.i686
gstreamer-plugins-bad-free-0.10.20-3.fc14.1.i686
gstreamer-plugins-bad-free-0.10.20-3.fc14.i686
gstreamer-plugins-base-0.10.30-2.fc14.i686
gstreamer-plugins-base-0.10.31-1.fc14.i686
gstreamer-plugins-good-0.10.25-1.fc14.i686
gstreamer-plugins-good-0.10.26-1.fc14.i686
gstreamer-python-0.10.16-2.fc14.i686
gstreamer-python-0.10.19-1.fc14.i686
gstreamer-rtsp-0.10.5-2.fc14.i686
gstreamer-tools-0.10.30-1.fc14.i686
gstreamer-tools-0.10.31-1.fc14.i686
gtk2-2.22.0-1.fc14.1.i686
gtk2-engines-2.20.1-2.fc14.i686
gtk2-immodule-xim-2.22.0-1.fc14.1.i686
gtk3-2.90.5-1.fc14.i686
gtk3-engines-2.90.3.1-4.fc14.i686
gtk3-immodule-xim-2.90.5-1.fc14.i686
gtkhtml2-2.11.1-8.fc14.i686
gtkhtml3-3.32.0-1.fc14.i686
gtkhtml3-3.32.1-1.fc14.i686
gtkimageview-1.6.4-2.fc14.i686
gtkmm24-2.22.0-1.fc14.i686
gtksourceview2-2.11.2-3.fc14.i686
gtkspell-2.0.16-1.fc13.i686
gtk-vnc-0.4.1-6.fc14.i686
gtk-vnc-0.4.2-4.fc14.i686
gucharmap-2.32.0-1.fc14.i686
guile-1.8.7-6.fc14.i686
gupnp-0.14.0-1.fc14.1.i686
gupnp-0.14.1-1.fc14.i686
gupnp-igd-0.1.7-2.fc14.i686
gutenprint-5.2.6-1.fc14.i686
gutenprint-5.2.6-2.fc14.i686
gutenprint-cups-5.2.6-1.fc14.i686
gutenprint-cups-5.2.6-2.fc14.i686
gvfs-1.6.4-2.fc14.i686
gvfs-1.6.6-1.fc14.i686
gvfs-afc-1.6.4-2.fc14.i686
gvfs-afc-1.6.6-1.fc14.i686
gvfs-archive-1.6.4-2.fc14.i686
gvfs-archive-1.6.6-1.fc14.i686
gvfs-fuse-1.6.6-1.fc14.i686
gvfs-gphoto2-1.6.4-2.fc14.i686
gvfs-gphoto2-1.6.6-1.fc14.i686
gvfs-obexftp-1.6.4-2.fc14.i686
gvfs-obexftp-1.6.6-1.fc14.i686
gvfs-smb-1.6.4-2.fc14.i686
gvfs-smb-1.6.6-1.fc14.i686
gvnc-0.4.1-6.fc14.i686
gvnc-0.4.2-4.fc14.i686
gzip-1.4-1.fc14.i686
hal-0.5.14-5.fc14.1.i686
hal-filesystem-0.5.14-5.fc14.1.i686
hal-info-20090716-3.fc12.noarch
hal-libs-0.5.14-5.fc14.1.i686
hdparm-9.27-1.fc13.i686
hesiod-3.1.0-19.fc14.i686
hicolor-icon-theme-0.12-1.fc13.noarch
hostname-3.04-2.fc14.i686
httpd-2.2.17-1.fc14.i686
httpd-tools-2.2.17-1.fc14.i686
hunspell-1.2.12-1.fc14.i686
hunspell-1.2.12-3.fc14.i686
hwdata-0.232-1.fc14.noarch
ibus-1.3.7-11.fc14.i686
ibus-1.3.9-2.fc14.i686
ibus-anthy-1.2.3-2.fc14.i686
ibus-anthy-1.2.5-3.fc14.i686
ibus-chewing-1.3.7.20100910-1.fc14.i686
ibus-chewing-1.3.9.2-1.fc14.i686
ibus-gtk2-1.3.7-11.fc14.i686
ibus-gtk2-1.3.9-2.fc14.i686
ibus-gtk3-1.3.7-11.fc14.i686
ibus-gtk3-1.3.9-2.fc14.i686
ibus-hangul-1.3.0.20100329-3.fc14.i686
ibus-libs-1.3.7-11.fc14.i686
ibus-libs-1.3.9-2.fc14.i686
ibus-m17n-1.3.1-4.fc14.i686
ibus-m17n-1.3.1-8.fc14.i686
ibus-pinyin-1.3.11-1.fc14.i686
ibus-pinyin-db-android-1.3.11-1.fc14.noarch
ibus-rawcode-1.3.1.20100707-1.fc14.i686
icedax-1.1.10-2.fc14.i686
icedax-1.1.11-1.fc14.i686
im-chooser-1.3.2-1.fc14.i686
im-chooser-1.4.0-1.fc14.i686
imsettings-0.108.1-2.fc14.i686
imsettings-libs-0.108.1-2.fc14.i686
info-4.13a-10.fc14.i686
info-4.13a-13.fc14.i686
initscripts-9.20.1-1.fc14.i686
iok-1.3.11-1.fc14.i686
iproute-2.6.35-3.fc14.i686
iproute-2.6.35-6.fc14.i686
iptables-1.4.9-1.fc14.i686
iptables-ipv6-1.4.9-1.fc14.i686
iptstate-2.2.2-4.fc14.i686
iputils-20100418-3.fc14.i686
ipw2100-firmware-1.3-11.fc13.noarch
ipw2200-firmware-3.1-4.fc13.noarch
irda-utils-0.9.18-10.fc12.i686
irqbalance-0.56-1.fc14.i686
iscsi-initiator-utils-6.2.0.872-8.fc14.i686
iso-codes-3.20-1.fc14.noarch
isomd5sum-1.0.6-2.fc14.i686
ivtv-firmware-20080701-20.noarch
iw-0.9.20-1.fc14.i686
iwl1000-firmware-128.50.3.1-2.fc13.noarch
iwl3945-firmware-15.32.2.9-4.fc13.noarch
iwl4965-firmware-228.61.2.24-2.fc12.noarch
iwl5000-firmware-8.24.2.12-3.fc13.noarch
iwl5150-firmware-8.24.2.2-1.fc13.noarch
iwl6000-firmware-9.221.4.1-1.fc14.noarch
iwl6050-firmware-41.28.5.1-2.fc14.noarch
jack-audio-connection-kit-1.9.5-1.fc14.i686
jack-audio-connection-kit-1.9.6-2.fc14.i686
jasper-libs-1.900.1-16.fc14.i686
jomolhari-fonts-0.003-9.fc14.noarch
json-glib-0.10.4-3.fc14.i686
kasumi-2.5-3.fc14.i686
kbd-1.15-11.fc14.i686
kbd-misc-1.15-11.fc14.noarch
kernel-2.6.35.10-74.fc14.i686
kernel-2.6.35.6-45.fc14.i686
kernel-headers-2.6.35.10-74.fc14.i686
keyutils-1.2-6.fc12.i686
keyutils-libs-1.2-6.fc12.i686
keyutils-libs-devel-1.2-6.fc12.i686
khmeros-base-fonts-5.0-10.fc14.noarch
khmeros-fonts-common-5.0-10.fc14.noarch
kpartx-0.4.9-14.fc13.i686
krb5-devel-1.8.2-7.fc14.i686
krb5-libs-1.8.2-6.fc14.i686
krb5-libs-1.8.2-7.fc14.i686
laughlin-backgrounds-gnome-14.1.0-1.fc14.noarch
laughlin-backgrounds-single-14.1.0-1.fc14.noarch
lcms-libs-1.19-2.fc14.i686
less-436-6.fc14.i686
less-436-9.fc14.i686
lftp-4.0.9-3.fc14.i686
libacl-2.2.49-8.fc14.i686
libaio-0.3.109-2.fc13.i686
libao-1.0.0-1.fc14.i686
libao-1.0.0-2.fc14.i686
libarchive-2.8.4-1.fc14.i686
libart_lgpl-2.3.21-1.fc14.i686
libass-0.9.11-1.fc14.1.i686
libass-0.9.11-1.fc14.i686
libassuan-2.0.0-2.fc14.i686
libasyncns-0.8-1.fc13.i686
libatasmart-0.17-2.fc13.i686
libattr-2.4.44-5.fc14.i686
libattr-2.4.44-6.fc14.i686
libavc1394-0.5.3-9.fc12.i686
libbeagle-0.3.9-6.fc14.i686
libblkid-2.18-4.3.fc14.i686
libblkid-2.18-4.7.fc14.i686
libbonobo-2.32.0-1.fc14.i686
libbonoboui-2.24.4-1.fc14.i686
libburn-0.8.0-1.fc14.i686
libcanberra-0.25-4.fc14.i686
libcanberra-gtk2-0.25-4.fc14.i686
libcanberra-gtk3-0.25-4.fc14.i686
libcap-2.17-1.fc13.i686
libcap-ng-0.6.4-4.fc14.i686
libcap-ng-0.6.5-1.fc14.i686
libcdaudio-0.99.12p2-13.fc12.i686
libcdio-0.82-2.fc13.i686
libcgroup-0.36.2-5.fc14.i686
libchewing-0.3.2-28.fc14.i686
libcollection-0.5.0-35.fc14.i686
libcollection-0.6.0-3.fc14.i686
libcom_err-1.41.12-5.fc14.i686
libcom_err-1.41.12-6.fc14.i686
libcom_err-devel-1.41.12-6.fc14.i686
libconfig-1.4.5-1.fc14.i686
libcroco-0.6.2-4.fc13.i686
libcurl-7.21.0-5.fc14.i686
libcurl-7.21.0-6.fc14.i686
libdaemon-0.14-1.fc13.i686
libdb-5.0.26-2.fc14.i686
libdc1394-2.1.2-3.fc12.i686
libdhash-0.4.0-35.fc14.i686
libdhash-0.4.2-3.fc14.i686
libdiscid-0.2.2-4.fc12.i686
libdmapsharing-1.9.0.21-1.fc14.i686
libdmx-1.1.0-1.fc13.i686
libdrm-2.4.22-1.fc14.i686
libdv-1.0.0-9.fc13.i686
libdvdnav-4.1.4-0.1.svn1184.fc12.i686
libdvdread-4.1.4-0.2.svn1188.fc13.i686
libedit-3.0-2.20090923cvs.fc14.i686
liberation-fonts-common-1.06.0.20100721-3.fc14.noarch
liberation-mono-fonts-1.06.0.20100721-3.fc14.noarch
liberation-sans-fonts-1.06.0.20100721-3.fc14.noarch
liberation-serif-fonts-1.06.0.20100721-3.fc14.noarch
libertas-usb8388-firmware-5.110.22.p23-4.fc13.noarch
libevent-1.4.14b-1.fc14.i686
libexif-0.6.19-1.fc14.i686
libffado-2.0.1-4.20100706.svn1864.fc14.i686
libffado-2.1.0-0.1.20101015.svn1913.fc14.i686
libffi-3.0.9-1.fc13.i686
libfontenc-1.0.5-2.fc12.i686
libfprint-0.2.0-1.fc14.i686
libfprint-0.3.0-1.fc14.i686
libfreebob-1.0.11-6.fc12.i686
libgcc-4.5.1-4.fc14.i686
libgcrypt-1.4.5-4.fc13.i686
libgdata-0.6.4-4.fc14.i686
libgee-0.5.2-2.fc14.i686
libgexiv2-0.2.0-1.fc14.i686
libglade2-2.6.4-3.fc12.i686
libgnome-2.32.0-1.fc14.i686
libgnomecanvas-2.30.2-1.fc14.i686
libgnomekbd-2.32.0-1.fc14.i686
libgnome-keyring-2.32.0-1.fc14.i686
libgnomeui-2.24.4-1.fc14.i686
libgomp-4.5.1-4.fc14.i686
libgpg-error-1.9-1.fc14.i686
libgphoto2-2.4.10-2.fc14.i686
libgpod-0.7.95-1.fc14.i686
libgpod-0.8.0-3.fc14.i686
libgtop2-2.28.2-1.fc14.i686
libgudev1-161-4.fc14.i686
libgudev1-161-8.fc14.i686
libgweather-2.30.3-1.fc14.i686
libgxim-0.3.3-3.fc12.i686
libhangul-0.0.10-1.fc13.i686
libhangul-0.0.12-1.fc14.i686
libhbaapi-2.2-10.fc14.i686
libhbalinux-1.0.10-1.fc14.i686
libical-0.43-5.fc12.i686
libical-0.46-2.fc14.i686
libICE-1.0.6-2.fc13.i686
libicu-4.4.1-3.fc14.i686
libicu-4.4.1-6.fc14.i686
libIDL-0.8.14-1.fc14.i686
libidn-1.18-1.fc14.i686
libiec61883-1.2.0-4.fc13.i686
libieee1284-0.2.11-9.fc14.i686
libimobiledevice-1.0.3-1.fc14.i686
libimobiledevice-1.0.4-1.fc14.i686
libini_config-0.6.0-35.fc14.i686
libini_config-0.6.1-3.fc14.i686
libiptcdata-1.0.4-3.fc14.i686
libisofs-0.6.34-1.fc14.i686
libisofs-0.6.40-1.fc14.i686
libjpeg-turbo-1.0.1-1.fc14.1.i686
libjpeg-turbo-devel-1.0.1-1.fc14.1.i686
libkate-0.3.7-2.fc14.i686
libldb-0.9.10-24.fc14.i686
libmcpp-2.7.2-4.fc14.i686
libmodman-1.0.1-5.fc14.i686
libmodplug-0.8.8.1-2.fc14.i686
libmount-2.18-4.3.fc14.i686
libmount-2.18-4.7.fc14.i686
libmpc-0.8.1-1.fc13.i686
libmpcdec-1.2.6-6.fc12.i686
libmtp-1.0.3-5.fc14.i686
libmtp-1.0.3-7.fc14.i686
libmusicbrainz3-3.0.2-7.fc14.i686
libmusicbrainz3-3.0.3-2.fc14.i686
libnetfilter_conntrack-0.0.101-1.fc13.i686
libnetfilter_conntrack-0.9.0-1.fc14.i686
libnfnetlink-1.0.0-1.fc13.i686
libnice-0.0.13-1.fc14.i686
libnih-1.0.2-2.fc14.i686
libnl-1.1-12.fc14.i686
libnotify-0.5.1-1.fc14.i686
libofa-0.9.3-16.fc12.i686
libogg-1.2.0-1.fc14.i686
liboil-0.3.16-4.fc12.i686
libotf-0.9.11-1.fc14.i686
libpanelappletmm-2.26.0-2.fc12.i686
libpath_utils-0.2.0-35.fc14.i686
libpath_utils-0.2.1-3.fc14.i686
libpcap-1.1.1-1.fc14.i686
libpciaccess-0.12.0-1.fc14.i686
libplist-1.3-2.fc14.i686
libpng-1.2.44-1.fc14.i686
libpng-devel-1.2.44-1.fc14.i686
libproxy-0.4.4-7.fc14.i686
libproxy-python-0.4.4-7.fc14.noarch
libpurple-2.7.3-4.fc14.i686
libpurple-2.7.9-1.fc14.i686
libraw1394-2.0.5-2.fc14.i686
libref_array-0.1.0-35.fc14.i686
libref_array-0.1.1-3.fc14.i686
librsvg2-2.32.0-1.fc14.i686
librsync-0.9.7-15.fc14.i686
libsamplerate-0.1.7-2.fc12.i686
libselinux-2.0.96-5.fc14.i686
libselinux-2.0.96-6.fc14.1.i686
libselinux-devel-2.0.96-6.fc14.1.i686
libselinux-python-2.0.96-5.fc14.i686
libselinux-python-2.0.96-6.fc14.1.i686
libselinux-utils-2.0.96-5.fc14.i686
libselinux-utils-2.0.96-6.fc14.1.i686
libsemanage-2.0.45-5.fc14.i686
libsemanage-python-2.0.45-5.fc14.i686
libsepol-2.0.41-3.fc14.i686
libsepol-devel-2.0.41-3.fc14.i686
libshout-2.2.2-5.fc12.i686
libsigc++20-2.2.4.2-1.fc12.i686
libsilc-1.1.10-4.fc14.i686
libSM-1.1.0-7.fc12.i686
libsmbclient-3.5.5-68.fc14.1.i686
libsmbclient-3.5.6-71.fc14.i686
libsndfile-1.0.21-1.fc14.i686
libsndfile-1.0.23-1.fc14.i686
libsoup-2.31.90-1.fc14.i686
libsoup-2.32.2-1.fc14.i686
libspectre-0.2.6-1.fc14.i686
libss-1.41.12-5.fc14.i686
libss-1.41.12-6.fc14.i686
libssh2-1.2.4-1.fc14.i686
libstdc++-4.5.1-4.fc14.i686
libsysfs-2.1.0-8.fc14.i686
libtalloc-2.0.1-1.fc13.i686
libtasn1-2.4-2.fc13.i686
libtasn1-2.7-1.fc14.i686
libtdb-1.2.1-3.fc14.i686
libtevent-0.9.8-7.1.fc14.i686
libthai-0.1.14-3.fc14.i686
libtheora-1.1.1-1.fc13.i686
libtiff-3.9.4-1.fc14.i686
libtool-ltdl-2.2.10-3.fc14.i686
libudev-161-4.fc14.i686
libudev-161-8.fc14.i686
libusb-0.1.12-23.fc14.i686
libusb1-1.0.8-1.fc14.i686
libuser-0.56.18-2.fc14.i686
libuser-0.56.18-3.fc14.i686
libuser-python-0.56.18-2.fc14.i686
libuser-python-0.56.18-3.fc14.i686
libutempter-1.1.5-4.fc12.i686
libuuid-2.18-4.3.fc14.i686
libuuid-2.18-4.7.fc14.i686
libv4l-0.8.1-1.fc14.i686
libvisual-0.4.0-9.fc12.i686
libvorbis-1.3.1-2.fc14.i686
libvpx-0.9.1-3.fc14.i686
libvpx-0.9.5-2.fc14.i686
libwnck-2.30.3-1.fc14.i686
libwnck-2.30.4-1.fc14.i686
libwvstreams-4.6.1-2.fc13.i686
libX11-1.3.4-3.fc14.i686
libX11-common-1.3.4-3.fc14.noarch
libX11-devel-1.3.4-3.fc14.i686
libXau-1.0.6-1.fc14.i686
libXau-devel-1.0.6-1.fc14.i686
libXaw-1.0.6-4.fc12.i686
libxcb-1.7-1.fc14.i686
libxcb-devel-1.7-1.fc14.i686
libXcomposite-0.4.2-1.fc14.i686
libXcursor-1.1.10-5.fc14.i686
libXdamage-1.1.3-1.fc14.i686
libXdmcp-1.0.3-3.fc13.i686
libXevie-1.0.2-8.fc13.i686
libXext-1.1.2-2.fc14.i686
libXfixes-4.0.5-1.fc14.i686
libXfont-1.4.2-1.fc14.i686
libXft-2.1.14-1.fc13.i686
libXi-1.3.2-1.fc14.i686
libXinerama-1.1-2.fc13.i686
libxkbfile-1.0.6-2.fc13.i686
libxklavier-5.0-1.fc13.i686
libxml++-2.30.1-1.fc14.i686
libxml++-2.33.1-1.fc14.i686
libxml2-2.7.7-2.fc14.i686
libxml2-python-2.7.7-2.fc14.i686
libXmu-1.0.5-2.fc13.i686
libXpm-3.5.8-2.fc13.i686
libXpm-devel-3.5.8-2.fc13.i686
libXrandr-1.3.0-5.fc13.i686
libXrender-0.9.6-1.fc14.i686
libXres-1.0.4-1.fc13.i686
libXScrnSaver-1.2.0-1.fc12.i686
libxslt-1.1.26-3.fc14.i686
libXt-1.0.7-1.fc13.i686
libXtst-1.0.99.2-3.fc12.i686
libXv-1.0.5-1.fc13.i686
libXvMC-1.0.5-1.fc13.i686
libXxf86dga-1.1.1-2.fc14.i686
libXxf86misc-1.0.2-1.fc13.i686
libXxf86vm-1.1.0-1.fc13.i686
linux-atm-libs-2.5.1-1.fc14.i686
linux-firmware-20100806-4.fc14.noarch
lklug-fonts-0.6-4.20090803cvs.fc14.noarch
lldpad-0.9.38-1.fc14.i686
lm_sensors-3.2.0-1.fc14.i686
lm_sensors-devel-3.2.0-1.fc14.i686
lm_sensors-libs-3.2.0-1.fc14.i686
lockdev-1.0.3-5.fc14.i686
logrotate-3.7.9-1.fc14.i686
lohit-assamese-fonts-2.4.3-5.fc14.noarch
lohit-bengali-fonts-2.4.3-5.fc14.noarch
lohit-devanagari-fonts-2.4.3-7.fc14.noarch
lohit-devanagari-fonts-2.4.3-8.fc14.noarch
lohit-gujarati-fonts-2.4.4-3.fc14.noarch
lohit-kannada-fonts-2.4.5-2.fc14.noarch
lohit-kannada-fonts-2.4.5-4.fc14.noarch
lohit-oriya-fonts-2.4.3-5.fc14.noarch
lohit-oriya-fonts-2.4.3-6.fc14.noarch
lohit-punjabi-fonts-2.4.4-1.fc14.noarch
lohit-tamil-fonts-2.4.5-6.fc14.noarch
lohit-telugu-fonts-2.4.5-5.fc14.noarch
lohit-telugu-fonts-2.4.5-6.fc14.noarch
lrzsz-0.12.20-27.fc12.i686
lsof-4.83-2.fc14.i686
lua-5.1.4-5.fc14.i686
lvm2-2.02.73-3.fc14.i686
lvm2-libs-2.02.73-3.fc14.i686
lx-20030328-5.fc12.i686
lzo-2.03-3.fc12.i686
m17n-contrib-1.1.12-2.fc14.noarch
m17n-db-1.6.1-3.fc14.noarch
m17n-db-1.6.2-1.fc14.noarch
m17n-lib-1.6.1-5.fc14.1.i686
m17n-lib-1.6.2-1.fc14.i686
m4-1.4.14-1.fc14.i686
mailcap-2.1.34-1.fc14.noarch
mailcap-2.1.35-1.fc14.noarch
make-3.82-2.fc14.1.i686
make-3.82-3.fc14.i686
makebootfat-1.4-10.fc14.i686
makebootfat-1.4-11.fc14.i686
man-db-2.5.7-2.fc14.i686
man-db-2.5.7-7.fc14.i686
mdadm-3.1.3-0.git20100722.2.fc14.i686
mdadm-3.1.3-0.git20100804.2.fc14.i686
meanwhile-1.1.0-4.fc13.i686
media-player-info-6-1.fc14.noarch
memtest86+-4.10-2.fc14.i686
mesa-dri-drivers-7.9-1.fc14.i686
mesa-dri-drivers-7.9-5.fc14.i686
mesa-libGL-7.9-1.fc14.i686
mesa-libGL-7.9-5.fc14.i686
mesa-libGLU-7.9-1.fc14.i686
mesa-libGLU-7.9-5.fc14.i686
metacity-2.30.3-1.fc14.i686
microcode_ctl-1.17-4.fc14.i686
microcode_ctl-1.17-7.fc14.i686
min12xxw-0.0.9-5.fc12.i686
mingetty-1.08-4.fc12.i686
mingetty-1.08-6.fc14.i686
mlocate-0.23.1-1.fc14.1.i686
mobile-broadband-provider-info-1.20100122-1.fc13.noarch
mod_dnssd-0.6-2.fc11.i586
mod_ssl-2.2.17-1.fc14.i686
ModemManager-0.4-4.git20100720.fc14.i686
module-init-tools-3.11.1-2.fc13.i686
mousetweaks-2.31.90-1.fc14.i686
mousetweaks-2.32.0-1.fc14.i686
mozilla-filesystem-1.9-5.fc12.i686
mpfr-2.4.2-1.fc13.i686
mtools-4.0.13-2.fc14.i686
nautilus-2.32.2.1-1.fc14.i686
nautilus-extensions-2.32.0-1.fc14.i686
nautilus-extensions-2.32.2.1-1.fc14.i686
nautilus-sendto-2.31.7-1.fc14.i686
nautilus-sendto-2.32.0-1.fc14.i686
nc-1.84-23.fc14.i686
ncftp-3.2.4-1.fc14.i686
ncurses-5.7-8.20100703.fc14.i686
ncurses-5.7-9.20100703.fc14.i686
ncurses-base-5.7-8.20100703.fc14.i686
ncurses-base-5.7-9.20100703.fc14.i686
ncurses-libs-5.7-8.20100703.fc14.i686
ncurses-libs-5.7-9.20100703.fc14.i686
neon-0.29.3-1.fc14.i686
neon-0.29.5-1.fc14.i686
net-snmp-5.5-21.fc14.i686
net-snmp-devel-5.5-21.fc14.i686
net-snmp-gui-5.5-21.fc14.i686
net-snmp-libs-5.5-21.fc14.i686
net-snmp-perl-5.5-21.fc14.i686
net-snmp-python-5.5-21.fc14.i686
net-snmp-utils-5.5-21.fc14.i686
net-tools-1.60-105.fc14.1.i686
NetworkManager-0.8.1-10.git20100831.fc14.i686
NetworkManager-0.8.1-9.git20100831.fc14.i686
NetworkManager-glib-0.8.1-10.git20100831.fc14.i686
NetworkManager-glib-0.8.1-9.git20100831.fc14.i686
NetworkManager-gnome-0.8.1-10.git20100831.fc14.i686
NetworkManager-gnome-0.8.1-9.git20100831.fc14.i686
NetworkManager-openconnect-0.8.1-1.fc14.i686
NetworkManager-openvpn-0.8.1-1.fc14.i686
NetworkManager-pptp-0.8.1-1.fc14.i686
NetworkManager-vpnc-0.8.1-1.fc14.i686
newt-0.52.12-1.fc14.i686
newt-python-0.52.12-1.fc14.i686
notification-daemon-0.5.0-1.fc14.i686
notify-python-0.1.1-15.fc14.i686
notify-python-0.1.1-16.fc14.i686
nspluginwrapper-1.3.0-14.fc14.i686
nspluginwrapper-1.3.0-15.fc14.i686
nspr-4.8.6-1.fc14.i686
nspr-4.8.7-1.fc14.i686
nss-3.12.7-6.fc14.i686
nss-3.12.9-1.fc14.i686
nss-mdns-0.10-8.fc12.i686
nss-softokn-3.12.7-6.fc14.i686
nss-softokn-3.12.9-1.fc14.i686
nss-softokn-freebl-3.12.7-6.fc14.i686
nss-softokn-freebl-3.12.9-1.fc14.i686
nss-sysinit-3.12.7-6.fc14.i686
nss-sysinit-3.12.9-1.fc14.i686
nss-util-3.12.7-2.fc14.i686
nss-util-3.12.9-1.fc14.i686
ntfs-3g-2010.10.2-1.fc14.i686
ntfs-3g-2010.8.8-2.fc14.i686
ntfsprogs-2.0.0-15.fc14.i686
ntp-4.2.6p2-7.fc14.i686
ntp-4.2.6p3-0.1.rc10.fc14.i686
ntpdate-4.2.6p2-7.fc14.i686
ntpdate-4.2.6p3-0.1.rc10.fc14.i686
ntsysv-1.3.47-1.fc14.i686
ntsysv-1.3.49-1.fc14.i686
obexd-0.29-1.fc14.i686
obex-data-server-0.4.5-1.fc13.i686
opencc-0.1.2-1.fc14.1.i686
opencc-0.2.0-1.fc14.i686
openconnect-2.25-1.fc14.i686
openconnect-2.26-4.fc14.i686
openjpeg-libs-1.3-10.fc14.i686
openjpeg-libs-1.3-9.fc14.i686
openldap-2.4.22-7.fc14.i686
openldap-2.4.23-4.fc14.i686
openldap-devel-2.4.23-4.fc14.i686
openobex-1.5-1.fc14.i686
openssh-5.5p1-21.fc14.2.i686
openssh-5.5p1-24.fc14.2.i686
openssh-askpass-5.5p1-21.fc14.2.i686
openssh-askpass-5.5p1-24.fc14.2.i686
openssh-clients-5.5p1-21.fc14.2.i686
openssh-clients-5.5p1-24.fc14.2.i686
openssh-server-5.5p1-21.fc14.2.i686
openssh-server-5.5p1-24.fc14.2.i686
openssl-1.0.0a-2.fc14.i686
openssl-1.0.0c-1.fc14.i686
openssl-devel-1.0.0c-1.fc14.i686
openvpn-2.1.1-2.fc13.i686
ORBit2-2.14.19-1.fc14.i686
orc-0.4.11-1.fc14.i686
orc-0.4.6-1.fc14.i686
orca-2.31.91-1.fc14.i686
orca-2.32.0-2.fc14.i686
PackageKit-0.6.11-2.fc14.i686
PackageKit-command-not-found-0.6.11-2.fc14.i686
PackageKit-device-rebind-0.6.11-2.fc14.i686
PackageKit-glib-0.6.11-2.fc14.i686
PackageKit-gstreamer-plugin-0.6.11-2.fc14.i686
PackageKit-gtk-module-0.6.11-2.fc14.i686
PackageKit-yum-0.6.11-2.fc14.i686
PackageKit-yum-plugin-0.6.11-2.fc14.i686
pakchois-0.4-3.i686
paktype-naqsh-fonts-3.0-3.fc14.noarch
paktype-naqsh-fonts-3.0-4.fc14.noarch
paktype-tehreer-fonts-2.0-10.fc14.noarch
paktype-tehreer-fonts-2.0-9.fc14.noarch
pam_passwdqc-1.0.5-6.fc13.i686
pam_pkcs11-0.6.2-6.fc14.i686
pam-1.1.1-5.fc14.i686
pam-1.1.1-6.fc14.i686
pango-1.28.1-4.fc14.i686
pangomm-2.26.2-1.fc14.i686
paps-0.6.8-14.fc14.i686
paps-libs-0.6.8-14.fc14.i686
papyon-0.5.2-1.fc14.noarch
paratype-pt-sans-fonts-20100408-1.fc14.noarch
parted-2.3-3.fc14.i686
parted-2.3-4.fc14.i686
passwd-0.78-1.fc14.i686
pbm2l2030-1.4-5.fc12.i686
pbm2l7k-990321-7.fc12.i686
pciutils-3.1.7-1.fc14.i686
pciutils-3.1.7-3.fc14.i686
pciutils-libs-3.1.7-1.fc14.i686
pciutils-libs-3.1.7-3.fc14.i686
pcmciautils-017-2.fc14.i686
pcre-8.10-1.fc14.i686
pcsc-lite-libs-1.6.4-1.fc14.i686
pcsc-lite-libs-1.6.4-3.fc14.i686
perl-5.12.2-140.fc14.i686
perl-Algorithm-Diff-1.1902-10.fc14.noarch
perl-AppConfig-1.66-8.fc14.noarch
perl-CGI-3.51-1.fc14.noarch
perl-CPAN-1.9402-140.fc14.noarch
perl-devel-5.12.2-140.fc14.i686
perl-Devel-Cover-0.66-1.fc14.i686
perl-Devel-Symdump-2.08-4.fc14.noarch
perl-Digest-SHA-5.47-140.fc14.i686
perl-ExtUtils-MakeMaker-6.56-140.fc14.noarch
perl-ExtUtils-MakeMaker-Coverage-0.05-10.fc14.noarch
perl-ExtUtils-ParseXS-2.2100-140.fc14.noarch
perl-FCGI-0.71-3.fc14.i686
perl-libs-5.12.2-140.fc14.i686
perl-Locale-Maketext-Simple-0.21-140.fc14.noarch
perl-Module-Pluggable-3.90-140.fc14.noarch
perl-Object-Accessor-0.36-140.fc14.noarch
perl-Params-Check-0.26-140.fc14.noarch
perl-parent-0.223-140.fc14.noarch
perl-Pod-Coverage-0.20-5.fc14.noarch
perl-Pod-Escapes-1.04-140.fc14.noarch
perl-Pod-POM-0.27-1.fc14.noarch
perl-Pod-Simple-3.13-140.fc14.noarch
perl-Template-Toolkit-2.22-6.fc14.i686
perl-Test-Differences-0.5000-2.fc14.noarch
perl-Test-Harness-3.17-140.fc14.noarch
perl-Text-Diff-1.37-4.fc14.noarch
perl-threads-1.81-1.fc14.i686
perl-threads-shared-1.32-140.fc14.i686
perl-Tk-804.028-12.fc14.i686
php-5.3.5-1.fc14.i686
php-cli-5.3.5-1.fc14.i686
php-common-5.3.5-1.fc14.i686
pilot-link-0.12.5-1.fc14.i686
pilot-link-0.12.5-2.fc14.i686
pinentry-0.8.0-3.fc14.i686
pinentry-gtk-0.8.0-3.fc14.i686
pixman-0.18.4-1.fc14.i686
pkcs11-helper-1.07-5.fc14.i686
pkgconfig-0.25-2.fc14.i686
planner-0.14.4-26.fc14.i686
planner-0.14.4-27.fc14.i686
plymouth-0.8.4-0.20100823.6.fc14.i686
plymouth-0.8.4-0.20100823.7.fc14.i686
plymouth-core-libs-0.8.4-0.20100823.6.fc14.i686
plymouth-core-libs-0.8.4-0.20100823.7.fc14.i686
plymouth-gdm-hooks-0.8.4-0.20100823.7.fc14.i686
plymouth-graphics-libs-0.8.4-0.20100823.6.fc14.i686
plymouth-graphics-libs-0.8.4-0.20100823.7.fc14.i686
plymouth-plugin-label-0.8.4-0.20100823.6.fc14.i686
plymouth-plugin-label-0.8.4-0.20100823.7.fc14.i686
plymouth-plugin-two-step-0.8.4-0.20100823.6.fc14.i686
plymouth-plugin-two-step-0.8.4-0.20100823.7.fc14.i686
plymouth-scripts-0.8.4-0.20100823.6.fc14.i686
plymouth-scripts-0.8.4-0.20100823.7.fc14.i686
plymouth-system-theme-0.8.4-0.20100823.7.fc14.i686
plymouth-theme-charge-0.8.4-0.20100823.6.fc14.i686
plymouth-theme-charge-0.8.4-0.20100823.7.fc14.i686
plymouth-utils-0.8.4-0.20100823.7.fc14.i686
pm-utils-1.3.1-2.fc14.i686
pm-utils-1.3.1-4.fc14.i686
pnm2ppa-1.04-19.fc14.i686
policycoreutils-2.0.83-28.fc14.i686
policycoreutils-2.0.83-33.10.fc14.i686
policycoreutils-python-2.0.83-28.fc14.i686
policycoreutils-python-2.0.83-33.10.fc14.i686
polkit-0.98-4.fc14.i686
polkit-desktop-policy-0.98-4.fc14.noarch
polkit-gnome-0.97-4.fc14.i686
poppler-0.14.4-1.fc14.i686
poppler-0.14.5-1.fc14.i686
poppler-data-0.4.3-1.fc14.noarch
poppler-data-0.4.4-1.fc14.noarch
poppler-glib-0.14.4-1.fc14.i686
poppler-glib-0.14.5-1.fc14.i686
poppler-utils-0.14.4-1.fc14.i686
poppler-utils-0.14.5-1.fc14.i686
popt-1.13-7.fc14.i686
popt-devel-1.13-7.fc14.i686
portreserve-0.0.4-5.fc14.i686
ppl-0.10.2-10.fc12.i686
ppp-2.4.5-12.fc14.i686
ppp-2.4.5-9.fc14.i686
pptp-1.7.2-9.fc14.i686
prelink-0.4.3-4.fc14.i686
printer-filters-1.1-4.fc12.noarch
procmail-3.22-25.fc12.i686
procps-3.2.8-12.fc14.1.i686
procps-3.2.8-15.fc14.i686
psacct-6.5.4-5.fc14.i686
psmisc-22.13-3.fc14.i686
psmisc-22.13-6.fc14.i686
psutils-1.17-36.fc14.i686
pth-2.0.7-9.i686
ptouch-driver-1.3-2.fc12.i686
pulseaudio-0.9.21-7.fc14.i686
pulseaudio-gdm-hooks-0.9.21-6.fc13.i686
pulseaudio-gdm-hooks-0.9.21-7.fc14.i686
pulseaudio-libs-0.9.21-6.fc13.i686
pulseaudio-libs-0.9.21-7.fc14.i686
pulseaudio-libs-glib2-0.9.21-6.fc13.i686
pulseaudio-libs-glib2-0.9.21-7.fc14.i686
pulseaudio-module-bluetooth-0.9.21-7.fc14.i686
pulseaudio-module-gconf-0.9.21-7.fc14.i686
pulseaudio-module-x11-0.9.21-7.fc14.i686
pulseaudio-utils-0.9.21-6.fc13.i686
pulseaudio-utils-0.9.21-7.fc14.i686
pyatspi-0.3.91-2.fc14.noarch
pyatspi-0.4.0-1.fc14.noarch
pycairo-1.8.8-2.fc14.i686
pyclutter-1.0.2-2.fc14.i686
pycryptopp-0.5.25-1.fc14.1.i686
pycryptopp-0.5.25-1.fc14.i686
pygobject2-2.21.5-3.fc14.i686
pygpgme-0.1-20.20090824bzr68.fc14.i686
pygpgme-0.1-21.20101027bzr69.fc14.i686
pygtk2-2.17.0-7.fc14.i686
pygtk2-libglade-2.17.0-7.fc14.i686
pygtksourceview-2.10.1-2.fc14.i686
pykickstart-1.77-2.fc14.noarch
pyOpenSSL-0.9-2.fc14.i686
pyOpenSSL-0.9-3.fc14.i686
pyorbit-2.24.0-6.fc14.i686
pyparted-3.4-3.fc14.i686
python-2.7-8.fc14.1.i686
python-beaker-1.5.3-5.fc14.noarch
python-BeautifulSoup-3.0.8.1-2.fc14.noarch
python-boto-1.9b-3.fc14.noarch
python-boto-1.9b-5.fc14.noarch
python-bugzilla-0.6.1-3.fc14.noarch
python-crypto-2.3-2.fc14.1.i686
python-crypto-2.3-2.fc14.i686
python-cryptsetup-0.0.10-3.fc14.i686
python-decorator-3.2.0-3.fc14.noarch
python-decorator-3.2.1-1.fc14.noarch
python-deltarpm-3.6-0.2.20100708git.fc14.i686
python-ethtool-0.5-1.fc14.i686
python-feedparser-4.1-12.fc14.noarch
python-GnuPGInterface-0.3.2-7.fc14.noarch
python-httplib2-0.6.0-3.fc14.noarch
python-iniparse-0.4-2.fc14.noarch
python-iwlib-0.1-3.fc14.i686
python-libs-2.7-8.fc14.1.i686
python-mako-0.3.4-2.fc14.noarch
python-markupsafe-0.9.2-4.fc14.i686
python-meh-0.10-2.fc14.noarch
python-nss-0.9-9.fc14.i686
python-paste-1.7.4-7.fc14.noarch
python-pyblock-0.52-1.fc14.i686
python-pycurl-7.19.0-7.fc14.i686
python-simplejson-2.1.1-3.fc14.i686
python-simplejson-2.1.3-1.fc14.i686
python-slip-0.2.13-1.fc14.noarch
python-slip-dbus-0.2.13-1.fc14.noarch
python-telepathy-0.15.18-1.fc14.noarch
python-tempita-0.4-5.fc14.noarch
python-urlgrabber-3.9.1-7.fc14.noarch
python-virtkey-0.50-8.fc14.i686
python-xlib-0.15-0.3.rc1.fc14.noarch
pywebkitgtk-1.1.6-5.fc14.i686
pyxdg-0.19-2.fc14.noarch
pyxf86config-0.3.37-10.fc14.i686
pyxf86config-0.3.37-8.fc14.i686
ql2500-firmware-5.03.07-1.fc14.noarch
ql2500-firmware-5.03.13-1.fc14.noarch
radeontool-1.5-6.fc12.i686
raptor-1.4.21-1.fc13.i686
rarian-0.8.1-5.fc12.i686
rarian-compat-0.8.1-5.fc12.i686
rasqal-0.9.20-1.fc14.i686
rasqal-0.9.21-1.fc14.i686
rdate-1.4-15.fc14.i686
rdist-6.1.5-49.fc14.i686
readahead-1.5.6-1.fc14.i686
readline-6.1-2.fc14.i386
redhat-menus-12.0.2-1.fc14.noarch
redland-1.0.10-7.fc14.i686
redland-1.0.12-1.fc14.i686
report-0.20-1.fc14.i686
report-config-bugzilla-redhat-com-0.20-1.fc14.i686
report-config-ftp-0.20-1.fc14.i686
report-config-localsave-0.20-1.fc14.i686
report-config-scp-0.20-1.fc14.i686
report-gtk-0.20-1.fc14.i686
report-newt-0.20-1.fc14.i686
report-plugin-bugzilla-0.20-1.fc14.i686
report-plugin-ftp-0.20-1.fc14.i686
report-plugin-localsave-0.20-1.fc14.i686
report-plugin-scp-0.20-1.fc14.i686
rhythmbox-0.13.1-1.fc14.i686
rhythmbox-0.13.2-1.fc14.i686
rmt-0.4-0.8.b43.fc14.i686
rng-tools-3-2.fc14.i686
rootfiles-8.1-6.fc12.noarch
rpm-4.8.1-5.fc14.i686
rpm-devel-4.8.1-5.fc14.i686
rpm-libs-4.8.1-5.fc14.i686
rpm-python-4.8.1-5.fc14.i686
rp-pppoe-3.10-6.fc12.i686
rsync-3.0.7-3.fc14.i686
rsyslog-4.6.3-1.fc14.i686
rsyslog-4.6.3-2.fc14.i686
rt61pci-firmware-1.2-7.fc13.noarch
rt73usb-firmware-1.8-7.fc13.noarch
rtkit-0.9-1.fc14.i686
samba-winbind-clients-3.5.5-68.fc14.1.i686
samba-winbind-clients-3.5.6-71.fc14.i686
sane-backends-1.0.21-3.fc14.i686
sane-backends-1.0.21-5.fc14.i686
sane-backends-libs-1.0.21-3.fc14.i686
sane-backends-libs-1.0.21-5.fc14.i686
sane-backends-libs-gphoto2-1.0.21-3.fc14.i686
sane-backends-libs-gphoto2-1.0.21-5.fc14.i686
schroedinger-1.0.10-1.fc14.i686
schroedinger-1.0.9-2.fc14.i686
seahorse-2.32.0-1.fc14.i686
sed-4.2.1-5.fc14.i686
seed-2.31.5-1.fc14.i686
seed-2.31.91-2.fc14.i686
selinux-policy-3.9.7-25.fc14.noarch
selinux-policy-targeted-3.9.7-25.fc14.noarch
sendmail-8.14.4-10.fc14.i686
sendmail-8.14.4-9.fc14.i686
setools-libs-3.3.7-11.fc14.i686
setools-libs-3.3.7-7.fc14.i686
setools-libs-python-3.3.7-11.fc14.i686
setools-libs-python-3.3.7-7.fc14.i686
setroubleshoot-3.0.23-1.fc14.i686
setroubleshoot-plugins-2.1.61-1.fc14.noarch
setroubleshoot-plugins-3.0.11-1.fc14.noarch
setroubleshoot-server-2.2.102-1.fc14.i686
setroubleshoot-server-3.0.23-1.fc14.i686
setserial-2.17-26.fc14.i686
setup-2.8.23-1.fc14.noarch
setup-2.8.28-1.fc14.noarch
setuptool-1.19.11-1.fc14.1.i686
setuptool-1.19.11-1.fc14.i686
sg3_utils-libs-1.29-1.fc14.i686
sgml-common-0.6.3-33.fc14.noarch
sgpio-1.2.0.10-4.fc12.i686
shadow-utils-4.1.4.2-8.fc14.i686
shadow-utils-4.1.4.2-9.fc14.i686
shared-color-profiles-0.1.1-1.fc14.noarch
shared-mime-info-0.71-4.fc14.i686
shared-mime-info-0.80-1.fc14.i686
shotwell-0.7.1-1.fc14.i686
shotwell-0.7.2-3.fc14.i686
sil-abyssinica-fonts-1.0-9.fc14.noarch
sil-padauk-fonts-2.4-6.fc13.noarch
simple-scan-2.32.0-1.fc14.i686
slang-2.2.2-2.fc14.i686
slv2-0.6.6-5.fc14.i686
slv2-0.6.6-6.fc14.i686
smc-fonts-common-4.4-2.fc14.noarch
smc-fonts-common-4.4-4.fc14.noarch
smc-meera-fonts-4.4-2.fc14.noarch
smc-meera-fonts-4.4-4.fc14.noarch
smolt-1.4.2.2-3.fc14.noarch
smolt-firstboot-1.4.2.2-3.fc14.noarch
smp_utils-0.94-3.fc12.i686
sos-2.2-1.fc14.noarch
sound-juicer-2.31.6-2.fc14.i686
sound-juicer-2.32.0-2.fc14.i686
sound-theme-freedesktop-0.7-2.fc13.noarch
speex-1.2-0.12.rc1.fc12.i686
sqlite-3.6.23.1-1.fc14.i686
squashfs-tools-4.1-0.3.20100803.fc14.i686
squashfs-tools-4.1-2.fc14.i686
sssd-1.3.0-35.fc14.i686
sssd-1.5.0-2.fc14.i686
sssd-client-1.3.0-35.fc14.i686
sssd-client-1.5.0-2.fc14.i686
startup-notification-0.10-4.fc13.i686
stix-fonts-1.0.0-1.fc14.noarch
stunnel-4.33-1.fc14.i686
stunnel-4.34-1.fc14.i686
sudo-1.7.4p4-3.fc14.i686
sudo-1.7.4p5-1.fc14.i686
symlinks-1.4-2.fc13.i686
syslinux-4.02-3.fc14.i686
system-config-date-1.9.61-1.fc14.noarch
system-config-firewall-1.2.27-1.fc14.noarch
system-config-firewall-base-1.2.27-1.fc14.noarch
system-config-firewall-tui-1.2.27-1.fc14.noarch
system-config-keyboard-1.3.1-2.fc14.i686
system-config-lvm-1.1.15-1.fc14.noarch
system-config-network-tui-1.6.2-1.fc14.noarch
system-config-printer-1.2.5-8.fc14.i686
system-config-printer-libs-1.2.4-2.fc14.i686
system-config-printer-libs-1.2.5-8.fc14.i686
system-config-printer-udev-1.2.4-2.fc14.i686
system-config-printer-udev-1.2.5-8.fc14.i686
system-config-users-1.2.105-1.fc14.noarch
systemd-units-10-2.fc14.1.i686
system-setup-keyboard-0.8.6-2.fc14.1.i686
system-setup-keyboard-0.8.6-3.fc14.i686
sysvinit-tools-2.87-5.dsf.fc14.i686
sysvinit-tools-2.87-7.dsf.fc14.i686
taglib-1.6.3-1.fc13.i686
talk-0.17-33.2.4.i686
tar-1.23-6.fc14.i686
tar-1.23-7.fc14.i686
tcl-8.5.8-2.fc14.i686
tcp_wrappers-7.6-59.fc14.i686
tcp_wrappers-devel-7.6-59.fc14.i686
tcp_wrappers-libs-7.6-59.fc14.i686
tcpdump-4.1.1-1.fc14.i686
telepathy-butterfly-0.5.14-1.fc14.noarch
telepathy-farsight-0.0.14-2.fc14.i686
telepathy-filesystem-0.0.2-1.fc12.noarch
telepathy-gabble-0.10.3-1.fc14.i686
telepathy-gabble-0.10.4-1.fc14.i686
telepathy-glib-0.11.16-1.fc14.i686
telepathy-haze-0.4.0-1.fc14.i686
telepathy-haze-0.4.0-2.fc14.i686
telepathy-idle-0.1.6-1.fc14.i686
telepathy-idle-0.1.7-1.fc14.i686
telepathy-logger-0.1.5-1.fc14.i686
telepathy-logger-0.1.7-1.fc14.i686
telepathy-mission-control-5.6.0-2.fc14.i686
telepathy-mission-control-5.6.1-1.fc14.i686
telepathy-salut-0.4.0-1.fc14.i686
thai-scalable-fonts-common-0.4.12-2.fc12.noarch
thai-scalable-fonts-common-0.4.14-1.fc14.noarch
thai-scalable-waree-fonts-0.4.12-2.fc12.noarch
thai-scalable-waree-fonts-0.4.14-1.fc14.noarch
tigervnc-license-1.0.90-0.22.20100813svn4123.fc14.1.noarch
tigervnc-license-1.0.90-0.22.20100813svn4123.fc14.noarch
tigervnc-server-minimal-1.0.90-0.22.20100813svn4123.fc14.1.i686
tigervnc-server-minimal-1.0.90-0.22.20100813svn4123.fc14.i686
time-1.7-37.fc12.i686
tmpwatch-2.10-1.fc14.i686
totem-2.32.0-1.fc14.i686
totem-mozplugin-2.32.0-1.fc14.i686
totem-nautilus-2.32.0-1.fc14.i686
totem-pl-parser-2.30.4-1.fc14.i686
traceroute-2.0.16-1.fc14.1.i686
transmission-common-2.04-2.fc14.1.i686
transmission-common-2.11-2.fc14.i686
transmission-gtk-2.04-2.fc14.1.i686
transmission-gtk-2.11-2.fc14.i686
tree-1.5.3-2.fc14.i686
tzdata-2010k-1.fc14.noarch
tzdata-2010o-1.fc14.noarch
udisks-1.0.1-4.fc14.i686
un-core-dotum-fonts-1.0.2-0.15.080608.fc14.noarch
un-core-fonts-common-1.0.2-0.15.080608.fc14.noarch
unique-1.1.6-1.fc13.i686
unzip-6.0-3.fc14.i686
upower-0.9.5-7.fc14.i686
upstart-0.6.5-10.fc14.i686
upstart-0.6.5-9.fc14.i686
upstart-sysvinit-0.6.5-10.fc14.i686
upstart-sysvinit-0.6.5-9.fc14.i686
urw-fonts-2.4-9.fc13.noarch
usb_modeswitch-1.1.4-1.fc14.i686
usb_modeswitch-data-20100817-1.fc14.noarch
usbmuxd-1.0.5-1.fc14.i686
usbmuxd-1.0.6-1.fc14.i686
usbutils-0.90-1.fc14.i686
usermode-1.106.1-1.fc14.1.i686
usermode-1.106.1-1.fc14.i686
usermode-gtk-1.106.1-1.fc14.1.i686
usermode-gtk-1.106.1-1.fc14.i686
ustr-1.0.4-9.fc12.i686
util-linux-ng-2.18-4.3.fc14.i686
util-linux-ng-2.18-4.7.fc14.i686
vconfig-1.9-8.fc12.i686
vim-minimal-7.2.446-2.fc14.i686
vim-minimal-7.3.056-1.fc14.i686
vinagre-2.31.4-1.fc14.i686
vino-2.31.91-1.fc14.i686
vino-2.32.0-1.fc14.i686
vlgothic-fonts-20100818-1.fc14.noarch
vlgothic-fonts-20101218-1.fc14.noarch
vlgothic-fonts-common-20100818-1.fc14.noarch
vlgothic-fonts-common-20101218-1.fc14.noarch
vorbis-tools-1.4.0-2.fc14.1.i686
vpnc-0.5.3-7.fc13.i686
vpnc-script-0.5.3-7.fc13.noarch
vte-0.26.1-1.fc14.i686
wavpack-4.60.1-1.fc14.i686
wavpack-4.60-1.fc12.i686
webkitgtk-1.3.10-1.fc14.i686
webkitgtk-1.3.4-3.fc14.1.i686
webkitgtk3-1.3.3-1.fc14.i686
wget-1.12-2.fc13.i686
which-2.19-5.fc12.i686
wireless-tools-29-5.1.fc12.i686
wodim-1.1.10-2.fc14.i686
wodim-1.1.11-1.fc14.i686
wpa_supplicant-0.6.8-10.fc14.i686
wqy-zenhei-fonts-0.9.45-5.fc14.noarch
wvdial-1.61-3.fc13.i686
xcb-util-0.3.6-1.fc12.i686
xdg-user-dirs-0.13-2.fc14.i686
xdg-user-dirs-gtk-0.8-5.fc13.i686
xdg-utils-1.0.2-20.20100709.fc14.noarch
xdg-utils-1.0.2-21.20101028.fc14.noarch
xfsprogs-3.1.2-1.fc14.i686
xkeyboard-config-1.9-6.fc14.noarch
xkeyboard-config-1.9-7.fc14.noarch
xml-common-0.6.3-33.fc14.noarch
xmlrpc-c-1.23.03-1400.svn1979.fc14.i686
xmlrpc-c-client-1.23.03-1400.svn1979.fc14.i686
xorg-x11-drivers-7.4-1.fc14.i686
xorg-x11-drv-acecad-1.4.0-4.fc14.i686
xorg-x11-drv-aiptek-1.3.0-4.fc14.i686
xorg-x11-drv-apm-1.2.3-1.fc14.i686
xorg-x11-drv-ast-0.89.9-1.fc12.i686
xorg-x11-drv-ati-6.13.1-0.3.20100705git37b348059.fc14.i686
xorg-x11-drv-cirrus-1.3.2-3.fc14.i686
xorg-x11-drv-dummy-0.3.4-1.fc14.i686
xorg-x11-drv-elographics-1.2.4-2.fc14.i686
xorg-x11-drv-evdev-2.5.0-1.fc14.i686
xorg-x11-drv-fbdev-0.4.1-4.fc14.i686
xorg-x11-drv-fpit-1.3.0-11.fc14.i686
xorg-x11-drv-geode-2.11.4.1-4.fc14.i686
xorg-x11-drv-geode-2.11.9-1.fc14.i686
xorg-x11-drv-glint-1.2.4-3.fc14.i686
xorg-x11-drv-hyperpen-1.3.0-5.fc14.i686
xorg-x11-drv-i128-1.3.3-3.fc14.i686
xorg-x11-drv-i740-1.3.2-3.fc14.i686
xorg-x11-drv-intel-2.12.0-6.fc14.1.i686
xorg-x11-drv-keyboard-1.4.0-5.fc14.i686
xorg-x11-drv-mach64-6.8.2-3.fc14.i686
xorg-x11-drv-mga-1.4.11-3.fc14.i686
xorg-x11-drv-mouse-1.5.0-5.fc14.i686
xorg-x11-drv-mutouch-1.2.1-7.fc14.i686
xorg-x11-drv-neomagic-1.2.5-1.fc14.i686
xorg-x11-drv-nouveau-0.0.16-11.20100826git065576d.fc14.i686
xorg-x11-drv-nv-2.1.15-6.fc14.i686
xorg-x11-drv-openchrome-0.2.904-8.fc14.i686
xorg-x11-drv-penmount-1.4.1-1.fc14.i686
xorg-x11-drv-qxl-0.0.20.f14b-6.fc14.i686
xorg-x11-drv-qxl-0.0.20.f14b-7.fc14.i686
xorg-x11-drv-r128-6.8.1-4.fc14.i686
xorg-x11-drv-rendition-4.2.4-1.fc14.i686
xorg-x11-drv-s3virge-1.10.4-3.fc14.i686
xorg-x11-drv-savage-2.3.1-3.fc14.i686
xorg-x11-drv-siliconmotion-1.7.3-4.20100122.fc14.i686
xorg-x11-drv-sis-0.10.3-1.fc14.i686
xorg-x11-drv-sisusb-0.9.4-1.fc14.i686
xorg-x11-drv-synaptics-1.3.0-1.fc14.i686
xorg-x11-drv-tdfx-1.4.3-3.fc14.i686
xorg-x11-drv-trident-1.3.4-1.fc14.i686
xorg-x11-drv-v4l-0.2.0-5.fc14.1.i686
xorg-x11-drv-vesa-2.3.0-1.fc14.i686
xorg-x11-drv-vmmouse-12.6.9-5.fc14.i686
xorg-x11-drv-vmware-11.0.1-1.fc14.i686
xorg-x11-drv-void-1.3.0-6.fc14.i686
xorg-x11-drv-voodoo-1.2.4-1.fc14.i686
xorg-x11-drv-wacom-0.10.8-1.20100726.fc14.i686
xorg-x11-drv-wacom-0.10.8-2.fc14.i686
xorg-x11-font-utils-7.4-2.fc14.i686
xorg-x11-font-utils-7.4-4.fc14.i686
xorg-x11-proto-devel-7.4-39.fc14.noarch
xorg-x11-server-common-1.9.0-15.fc14.i686
xorg-x11-server-common-1.9.3-4.fc14.i686
xorg-x11-server-utils-7.4-19.fc14.i686
xorg-x11-server-Xorg-1.9.0-15.fc14.i686
xorg-x11-server-Xorg-1.9.3-4.fc14.i686
xorg-x11-utils-7.4-10.fc14.i686
xorg-x11-xauth-1.0.2-7.fc12.i686
xorg-x11-xinit-1.0.9-18.fc14.i686
xorg-x11-xkb-utils-7.4-8.fc14.i686
xorg-x11-xkb-utils-7.5-1.fc14.i686
xulrunner-1.9.2.10-1.fc14.1.i686
xulrunner-1.9.2.13-5.fc14.i686
xz-4.999.9-0.2.beta.20100401git.fc14.i686
xz-libs-4.999.9-0.2.beta.20100401git.fc14.i686
yelp-2.30.2-1.fc14.i686
yum-3.2.28-5.fc14.noarch
yum-langpacks-0.1.5-3.fc14.noarch
yum-metadata-parser-1.1.4-2.fc14.i686
yum-presto-0.6.2-2.fc14.noarch
yum-utils-1.1.28-1.fc14.noarch
zd1211-firmware-1.4-4.fc13.noarch
zenity-2.32.0-1.fc14.i686
zip-3.0-2.fc14.i686
zlib-1.2.5-2.fc14.i686
zlib-devel-1.2.5-2.fc14.i686
ok and where are you expecting the 'libexec' folder to be?
Btw why are you compiling from sources?
the libexec folder is at /usr/local/nagios/
it has all the other check_xxx in hence why I'm looking there.
As fro compiling, I'm just doing what the guide said. download plugin.tar.gz, unpack, cd to folder, run ./configure, run make, run make install.
Is there a better way that will give me what I'm after?
Thanks again for your time :)
Yeah, can't you just install the Nagios package from the updates repository along with nagios-plugins-snmp?
Code:
yum install nagios nagios-plugins-snmp
Cheers.
That has installed and shows up in my installed packages list but there is still no check_snmp in linbexec.
was thee anything else I needed to do?
nagios-plugins-snmp-1.4.15-2.fc14.i686
are all installed, but nothing in libexec relates to check_snmp.
thanks again guys.
oh!!
I found it in /usr/lib/nagios/plugins
Which is I belive the old location for nagios to store it's plugins in. I've copied to libexec and it seems to be working, I just need to hammer out some test runs.
Cheers guys you both where a massive help :)
oh!!
since you installed the rpm it goes in /usr/lib/ if you (make) install from source with the default prefix it goes it /usr/local/lib.
if you do an rpm -qf of check_snmp you should find it comes from that package nagios-plugins-snmp-1.4.15-2.fc14.i686.
If I were you I would bin your install and either do the whole thing with yum - or none of it and compile it all. Also you should look into some nagios admin guis (like centreon) - great time savers.
Its really a pain to get nagios working..I did check someone on WHT who's got an script to get nagios installed ..I will search for it and let you know.
I implemented Nagios across 50 sites using a star topology, monitoring windows servers, switches etc.
