- 11 Dec 2005
- Cheshire
Introducing our sweet new "Nano 150i MEDIA" mini ITX media system. Providing tiny dimensions with low power consumption and great performance. perfect for any home media, office of work system, VESA compatible too
"Nano 150i MEDIA" Intel Atom 1.60GHz DDR3 Complete Media System @ £175.49 inc VAT
The "Nano 150i MEDIA" system is based on the fantastic ZOTAC ZBOX SD-ID12 mini-PC Inside the ZOTAC ZBOX SD-ID12 mini-PC is a 32GB SSD and 2GB DDR3 DIMM module while USB 2.0, eSATA and a 6-in-1 memory card reader (SD/SDHC/MS/MS Pro/xD/MMC) provide external expansion. Perfect for any media system requirements with it's small and discreet foot print.
System Specifications
• Intel® Atom™ D525 CPU (1.8 GHz, dual-core)
• Intel® NM10 Express chipset
• Intel® Graphics Media Accelerator 3150 GPU
Inside the box
• ZOTAC ZBOX SD-ID12
• Power brick & cable
• VESA monitor mount (w/4 screws)
• Stand
WWW.ZOTAC.COM
SKU: ZBOXSD-ID12
Internal Expansion
• x1 2.5-inch 32GB SSD (hard drive upgrade available)
• x1 2GB DDR3 SO-DIMM (4GB upgrade available)
Display Outputs
• HDMI (720p)
• HDCP compliant
• VGA
Front Ports
• Headphone/Audio out jack
• Microphone jack
• 6-in-1 Memory card reader
• (MMC/SD/SDHC/MS/MS Pro/xD)
• 1 USB 2.0 port
• WiFi LED
• Hard drive LED
• Power button
Features
• Intel® HyperThreading technology
• Intel® ClearVideo (SD) technology
• Microsoft® DirectX® 9 compatible
• OpenGL® 1.5 compatible
• Energy-efficient computing
Dimensions
• Length: 7.40in - 188mm
• Width: 7.40in - 188mm
• Depth: 1.73in - 44mm
Rear Ports
• eSATA
• 4 USB 2.0 ports
• 10/100/1000 Ethernet (RJ45)
• Digital S/PDIF output
• Power connector
Top Ports
• 1 USB 2.0 port
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Tiny dimensions, low power consumption and awesome styling. The "Nano 150i MEDIA" is the perfect discreet media system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
*Buy any system from Overclockers UK with Windows 7 between now and January 31st 2013 and once launched, you can upgrade to Windows 8 for just £14.99! See full details here:http://www.overclockers.co.uk/LP/windows8_upgrade.php
Only £175.49 inc VAT.
ORDER NOW
Inside the box
• Stand
WWW.ZOTAC.COM
SKU: ZBOXSD-ID12
Internal Expansion
Display Outputs
• HDMI (720p)
• HDCP compliant
• VGA
Front Ports
• Microphone jack
• 1 USB 2.0 port
• WiFi LED
• Hard drive LED
• Power button
Features
Dimensions
Rear Ports
• eSATA
• 4 USB 2.0 ports
• Power connector
Top Ports
• 1 USB 2.0 port
Service Package
ORDER NOW
