- 11 Dec 2005
- Cheshire
Hi guys,
Today we introduce a new range of "Nano" mini ITX bundles. Ultra small form factor and they are packing some serious heat! Available in varying chipsets and CPUs, so there is a bundle for everyone!
Nano AMD E350 Mini ITX Bundle - Dual Core @ £139.98 inc VAT
Designed by experts the "NANO E350 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "NANO E350 Bundle" offers you speed and silence in perfect combination.
Why You Should Buy This Bundle?
- Prebuilt and configured. Just "plug and play"
- 8GB of Dual Channel DDR3 memory delivers fast load times
- Power saving processing for superior computing performance
Bundle Specification
- CPU: AMD E350 1.60GHz Dual Core CPU
- Motherboard: Gigabyte GA-E350N-USB3 AMD Hudson M1 DDR3 Motherboard
- RAM: 8GB DDR3 1600MHz Dual Channel
- Cooler: AMD Passive Cooler
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £139.98 inc VAT.
ORDER NOW
Nano Intel Atom D525 1.60GHz Mini ITX Bundle - Dual Core @ £102.98 inc VAT
Designed by experts the "NANO Atom Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "NANO Atom Bundle" offers you speed and silence in perfect combination.
- 4GB of Single Channel DDR3 memory delivers fast load times
- CPU: Intel Atom D525 1.60 Dual Core CPU
- Motherboard: Gigabyte GA-D525TUD DDR3 Motherboard
- RAM: 4GB DDR3 1333MHz Single Channel
- Cooler: Passive CPU Cooler
Service Package
Only £102.98 inc VAT.
ORDER NOW
Nano H61 Intel Celeron G540 2.50GHz Mini ITX Bundle - Dual Core @ £99.98 inc VAT
Designed by experts the "NANO H61 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "NANO H61 Bundle" offers you speed and silence in perfect combination.
- CPU: Intel Celeron 540 2.50GHz Dual Core CPU (Upgrade options available)
- Motherboard: MSI H61I-E35 Intel H77 (Socket 1155) DDR3 Motherboard
- Cooler: Intel Stock Cooler
Service Package
Only £99.98 inc VAT.
ORDER NOW
Nano H77 Intel Core i3 3220 3.30GHz Mini ITX Bundle - Dual Core @ £249.98 inc VAT
Designed by experts the "NANO H77 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "NANO H77 Bundle" offers you speed and silence in perfect combination.
- CPU: Intel Core i3 3220 3.30GHz Dual Core CPU
- Motherboard: Asus P8H77-I Intel H77 (Socket 1155) DDR3 Motherboard
Service Package
Only £249.98 inc VAT.
ORDER NOW
Nano Z77 Intel Core i5 3450 3.10GHz Mini ITX Bundle - Quad Core @ £387.97 inc VAT
Designed by experts the "Nano Z77 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Nano Z77 Bundle" offers you speed and silence in perfect combination.
- 16GB of Dual Channel DDR3 memory delivers fast load times
- CPU: Intel Core i5 3540 3.10GHz Quad Core CPU (Upgrade options available)
- Motherboard: Asrock Z77E-ITX Intel Z77 (Socket 1155) DDR3 Motherboard (Upgrade options available)
- RAM: 16GB DDR3 1600MHz Dual Channel
Service Package
Only £387.97 inc VAT.
ORDER NOW
![BU-079-OP_400.jpg](http://overclockers.co.uk/pimg/BU-079-OP_400.jpg)
Service Package
ORDER NOW
![BU-082-OP_400.jpg](http://overclockers.co.uk/pimg/BU-082-OP_400.jpg)
Service Package
ORDER NOW
![BU-125-OE_400.jpg](http://overclockers.co.uk/pimg/BU-125-OE_400.jpg)
Service Package
ORDER NOW
![BU-080-OP_400.jpg](http://overclockers.co.uk/pimg/BU-080-OP_400.jpg)
Service Package
ORDER NOW
![BU-081-OP_400.jpg](http://overclockers.co.uk/pimg/BU-081-OP_400.jpg)
Service Package
ORDER NOW
