NANO RANGE OF COMPLETE MINI PCS!!!
11 Dec 2005
Cheshire
We have launched a new range of mini PCs which are perfect if you are limited on space and need a small form factor machine which holds great power. Mini PCs are perfect for home theatres as their compact size makes it great to store near a large screen without being in the way. You can also mount a few of the systems onto the back of a computer monitor with a VESA mount, making it a very space effective solution.
"Nano 100a" AMD Hudson 1.60GHz Dual Core System @ £273.98 inc VAT
Introducing the new "Nano" range of ultra small, energy efficient, media systems. With VESA mounting compaitbilty and silent operation making for a system perfectly suited to the home or in the office as a business system. A small size means that less space is taken up allowing for a cleaner, clearer working environment, when utilising the VESA mount, the Nano can stay tucked away out of sight. Utilising the latest AMD Fusion onboard APU for ultra low power consumption whilst providing excellent dual core processing power with sharp, fluid DX11 cinematic graphics.
Why You Should Buy This System?
- AMD Fusion APU E-350 1.60GHz offers power saving hyperthreading performance
- 8 Hours stressed tested and quality controlled
- 160GB hard drive gives a solid and reliable storage capacity.
- 4GB of 1600MHz DDR3 RAM allows for snappy and precise processes to be made.
System Specification
- Case: Antec ISK110 - Black
- Power Supply: 90W AC Adaptor
- CPU: AMD Fusion APU E-350 1.60GHz Dual Core
- Motherboard: AMD FCH A50 DDR3 Motherboard
- RAM: 4GB DDR3 1600MHz Single Channel Kit
- Hard Drive: 160GB HDD
- Graphics Card: Integrated ATI Radeon™ HD 6310 GPU
- Sound: 7.1 channel HD Audio
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Ultra small size, perfect for putting behind your monitor or TV. Excellent streaming capabilities and low power consumption make the "Nana 100a" the intelligent choice.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £273.98 inc VAT.
ORDER NOW
"Nano 110a" AMD Hudson 1.65GHz Dual Core System @ £323.99 inc VAT
- AMD Fusion APU E-450 1.65GHz offers power saving hyperthreading performance
- CPU: AMD Fusion APU E-450 1.65GHz Dual Core
- Motherboard: AMD FCH A50M DDR3 Motherboard
- Graphics Card: Integrated ATI Radeon™ HD 6320 GPU
Service Package
Ultra small size, perfect for putting behind your monitor or TV. Excellent streaming capabilities and low power consumption make the "Nana 110a" the intelligent choice.
Only £323.99 inc VAT.
ORDER NOW
"Nano 100i" Intel Atom 1.80GHz Dual Core System @ £223.99 inc VAT
Introducing the new "Nano" range of ultra small, energy efficient, media systems. With VESA mounting compaitbilty and silent operation making for a system perfectly suited to the home or in the office as a business system. A small size means that less space is taken up allowing for a cleaner, clearer working environment, when utilising the VESA mount, the Nano can stay tucked away out of sight. Utilising the latest Intel Atom onboard CPU for ultra low power consumption.
- Intel Atom D525 1.80GHz offers power saving performance
- CPU: Intel Atom D525 1.80GHz Dual Core
- Motherboard: Intel NM10 DDR3 Motherboard
- Graphics Card: Integrated Intel Graphics
Service Package
Ultra small size, perfect for putting behind your monitor or TV. Excellent streaming capabilities and low power consumption make the "Nana 100i" the intelligent choice.
Only £223.99 inc VAT.
ORDER NOW
"Nano 110i" Intel Core i3 3.10GHz Dual Core System @ £323.99 inc VAT
Introducing the new "Nano" range of ultra small, energy efficient, media systems. With VESA mounting compaitbilty and silent operation making for a system perfectly suited to the home or in the office as a business system. A small size means that less space is taken up allowing for a cleaner, clearer working environment, when utilising the VESA mount, the Nano can stay tucked away out of sight. Utilising the latest Intel HD 2000 onboard GPU for ultra low power consumption whilst providing excellent dual core processing power with sharp, fluid DX10 cinematic graphics.
- Intel Core i3 2100 3.10GHz offers power saving performance
- Power Supply: 65W AC Adaptor
- CPU: Intel Core i3 2100 3.10GHz Dual Core
- Motherboard: Intel H61 DDR3 Motherboard
- Graphics Card: Integrated Intel HD 2000 Graphics
Service Package
Ultra small size, perfect for putting behind your monitor or TV. Excellent streaming capabilities and low power consumption make the "Nana 110i" the intelligent choice.
ORDER NOW
Looks good, what cpu cooler are you using on the i3 system?
Also I noticed that the i3 system is quoted to have a 65W psu, mistake possibly as the other ones all have 90W psu's.
I've speced the sam system with a Gigabyte bord, 60GB OCZ SSD and 8GB for £347.95 else where. Thats better spec!
Shenanigans I specced this up (The same spec as in the product description, 110i) and it is only £10 more than bought separately which I think is a very very fair price for building a PC for you.
edit: actually it is even cheaper now so it costs less than bought separately from a competitor.
These are great systems for htpc's! I have an almost identical system using the E350 which I built myself and its really good.
What's up with the vesa mount though? DO they come with the Antec case these days and if not are they available seperately as could be quite handy.
No fan on the psu in that antec case. The case has a fan mounted on the one side whcih is whisper quiet. The side is a kind of open grill with the fan in the centre so venilation is not an issue
