Hi guys,
Some of you might have seen my thread a week or so ago about a 8-900 machine (pre-build from OC). Situation has changed a little and I am not looking at around the £1100 mark
So,the two systems I am looking at are either the:
Titan exodus - http://www.overclockers.co.uk/showproduct.php?prodid=FS-252-OK&groupid=43&catid=1444&subcat=
or the
Titan goliath MKII - http://www.overclockers.co.uk/showproduct.php?prodid=FS-034-OP&groupid=43&catid=1444&subcat=
Obviously there will be some difference in optionals,
The exodus would have - GTX 480 + Corsair Force 60GB F60 2.5" SATA-ll Solid State Drive
The goliath MKII would have - Corsair Force 60GB F60 2.5" SATA-ll Solid State Drive + the base GPU (to be upgraded to the GTX 480 in about 2-3months).
For either system, I would also be looking to upgrade the RAM in about a years time - would that be possible?
The main things the system will be doing is gaming (WoW + SC2 mainly).
The final thing the system will need is a wireless card suitable for gaming - unfortunately I know very little about network cards and am hoping someone can suggest something suitable.
Thanks,
Madals
or the
Thanks,
Madals
