Ok the main problem atm with my screen is it constantly blacks out. For seconds or longer atm. Been trying to figure out what is causing it through some testing etc, just need some ideas.
Monitor:
Hanns G 28"
1920x1200
DVI to HDMI
Testing:
Monitor plugged in to another pc, new power cable, same HDMI. No problems any more.
Back on main pc, new power cable, same HMDI. Still blacking.
New power cable, same HDMI, swapped with the gfx card connector the 2nd screen is in. No difference, still blacking.
Lower Res. Major corruption more frequent blacking.
Analogue cable instead of HDMI. distortion on picture, then perminant black out.
Now I just need some advice on what could cause it to work fine on the 2nd pc downstairs but not up here!
PC spec if needed:
amd X2 6000
6gb ram
4890 1gb
Monitor:
Hanns G 28"
1920x1200
DVI to HDMI
Testing:
PC spec if needed:
amd X2 6000
6gb ram
4890 1gb
