FMTopfan - No offence but that is a load of misinformation you posted, pretty much everything is incorrect bar the RAID5 comment.
Infamous786 - It sounds like the DS411J would be ideal for your requirements. I've personally got a DS211J (got it today) and it's great, especially for streaming media to my Apple TV and PS3.
As for hard drives, I'd recommend filling it up with as many as you can afford. I went with the Samsung Spinpoint F4 EcoGreen 2TB (HD204UI) and they are working great in RAID1 however they did need a firmware update before they were installed, lots of people on the Synology forums love the WD Caviar Green drives and they are fully compatible with all the Synology DiskStations. I'd recommend going with energy-saving drives (or Western Digital AV-GP drives) as you won't see the benefits of a 7200rpm performance drive over Ethernet.
If your going to fill all 4 drives I'd recommend either RAID10, RAID5 or RAID6. I'll outline the pro's/con's below:
RAID10 w/ 4x 2TB HDD
Capacity: 4096 GB
Speed gain: 4x read and 2x write speed gain
Fault tolerance: At least 1-drive failure
RAID5 w/ 4x 2TB HDD
Capacity: 6144 GB
Speed gain: 3x read speed, no write speed gain
Fault tolerance: 1-drive failure
RAID6 w/ 4x 2TB HDD
Capacity: 4096 GB
Speed gain: 2x read speed, no write speed gain
Fault tolerance: 2-drive failure
The above RAID levels are all supported by the DS411J.
My transfer speeds are ~40Mb/s read and ~60Mbps write so I'd guess the DS411J would be slightly faster given the amount of drives, they both have the same amount of RAM and CPU clock speed.
Hope that helps, let me know if you have any questions
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
