NAS or devicethat can act as a USB drive
  • Thread starter Thread starter Deleted member 66701
  • Start date Start date
D
I have a device (3D printer) that has a USB port that you use to upload print files. Is there any kind of NAS or device that I can upload files to over ethernet but that I can also plug into the printer, and the printer will see it as a regular USB drive?
WD My cloud
I have two MyCloud devices - the USB port is input only - i.e. you plug a USB drive into it then you can access the USB drive over the network - I'm looking for it to be the other way round (transfer files to a device over the network and have that device readable by the printer as a USB drive).
just found a wifi enabled SD card (Toshiba Flashair) that should do the trick :-)
