I want to store, and stream, my movies to my TV via my Denon receiver and for the movies to be accessible on the home network. I'm a simple man and really dont have that much in the way of storage requirements. I expect to only use 2TB or at a push 4TB but 2 is plenty.
At the moment my setup works quite well as I have movies on my iMac and stream using Plex to my Firestick and then onto the TV via the Denon. All works well but as I gradually increase my ripping of my movies I can see a need to take them off the iMac. I also have a Dune HD which works well but I expect will have to go if I set this up right. I hardly use it now
My original intention was to go for a microserver, my son had a HP Gen 8, but he does quite a bit on it but given my, relative, low storage requirements its seems overkill. I dont use 4k like him but may in the future of course. So my thoughts turned to a NAS. Had a 2 bay Qnap on Raid 1 before and it worked fine. But my current thoughts were single Bay, prob Syntology, with USB drive as a backup on the basis of cost and simplicity. Most of my files are .mkv and 1080p as is the TV.
But I keep going round in circles on this. Syntology DS-118 keeps popping up with either 2TB or 4TD and matching USB backup drive.
Thank you for you patience and any advice appreciated
