- 26 Apr 2004
- Milton Keynes
Hi Guys,
Was wondering if anyone has done any 'side by side' testing to find the best performing SAMBA NAS OS/software setup?
I have an i3-2100 with 4GB RAM serving multiple NTFS HDDs round my home network, and now also my unified Steam folder, and I've noticed that SAMBA is definitely bottlenecking performance, more than I'd expected in some cases. (Most games work pretty seemlessly fine, but Borderlands: The PreSequel for example takes over 5 **minutes** to load over LAN rather than on the clients internal HDDs)
I've had no luck at getting NFS to the state it 'just works' on Win10 clients without a lot more configuration than I'm comfortable and ISCSI doesn't seem to fit the profile of what I want to do (multiple clients accessing the same files at the same time from the same partition) and seems a bit awkward to get running. I'm not a Linux/Networking guru so some of it may just have gone over my head!
So far, OpenElec is the easiest, it basically just works, and very easily, it also has good write performance, read speed is decent but not amazing, and was a leftover from when the server actually was a media machine.
NAS4Free 11 with ASIO and large read/write enabled has better read speeds (about 20-30% in some cases), but write speeds take a massive hit. ~100MBps -> 40MBps on sequential for example.
I'd seen that NAS4Free v9 had better SAMBA performance, but it doesn't seem to like one of my NTFS partitions, and also cannot seem to get it to just accept an anonymous CIFS connection from a windows machine or broadcast properly like V11 does.
As it stands, I've gone back to OpenELEC for simplicity, I did look at FreeNAS briefly but note it seems to want more than 4GB RAM.
Anyone found themselves in a similar predicament, tested out the various free NAS OS solutions etc and can share results and save me some time?
