Nasty noise on engine spooldown?
24 Apr 2007
Southport
Hi all,
When doing my cambelt I noticed a rather nasty rattling noise coming from the exhaust manifold / turbo area upon spool down (revving to 4k and letting go of the throttle makes it happen, only on the engine slowing to idle though)
If I didn't know better, I'd say it sounded like turbo blades hitting the casing... so panicking I whipped the airbox off and checked for play in the shaft. Turns out there is no lateral play, and very little up/down play, so seems this cannot be the issue.
Also, being the inventive person I am I took the outlet pipe from the turbo off the intercooler and shoved my ear in it, and did a few rev tests - on spool down the same nasty noise happened but wasn't noticeably coming from the turbo via the pipe.
I know the cat is rattly, every time I hit a slight bump at low speeds it rattles to hell.
Any ideas what the noise on spool down is though?
As soon as I read the first line, I thought actuator rattle.
When are you next in work? I'll have a listen if you like. I'm not fixing it for you though... space is *tight* even for my little girl hands! :p
Cheers mate, in every day until the end of next week apart from tomorrow :p
Also think the PAS pump is ****ed... :D
You seem very upbeat about what sounds like a car which is giving issues after only a very short time :p
Hardly an issue, my old diesel made lots of horrible noises :p just feel that because this car is pretty much mint, it's a shame to have a rattle like that.
No major issues, car is running sweeeeeet and boosts like hell :D
So much nicer than my tractor :p
A rattling actuator is hardly the end of the world. It can happen to any car, not just because it's a Rover ;)
What time do you finish today Mat?
I'm in training until 5:30.
