native resolution
27 Sep 2005
Cornwall / Helston
hey all,
Got my new pc up and running, all was fine until my last restart, when posting and booting the screen now says out of range. the other thing is when i loaded up a game it informed me it was in the wrong resolution when i had previously set it.
In the nvidia control panel it also displays the wrong native resolution when it never used to.
Also the 4 way micro switch on the monitor has stopped working?
Running latest drivers
Any ideas?
Spec;
LG 27gl850b
gigabyte 2020
AMD 3700
MSI 450 carbon AC
16gb Patriot vipor
Install the proper driver for your monitor if it has one and see if the RES issue resolves itself, it is not DSR as that would still make your monitor's Native RES in there be marked as Native RES..
Seems I can't install a driver for the monitor? It prefers the win10 driver. What do you mean by DSR?
Uninstall the driver, shut down your system, and reset your cmos. Boot back up and reinstall the driver.
Tried this, unfortunately still not resolved
I'm finding strange that the 4 way selector no longer works for the monitor, if I change monitor cable it displays the option to change to that cable and the up, down, left and right work but pressing the button to select doesn't?
I believe windows 10 thinks I now have an lg ultra HD monitor installed as well has the lg monitor software?
Here you can see the lg software reporting the monitor as a Ultra HD
And here you can see when i start the PC it reports in the wrong resolution
Had a chat with LG, waste of time very blunt, offered no insight and just told me to return it. Just had a chat with OC'ers and they have arranged for collection tomorrow with a hopeful replacement delivered Wednesday
