nb block for rampage formula
3 Aug 2008
Bath, England
hi peeps, having a very stressful day; recieved a load of water kit over the past few weeks as i decided i was going to fully watercool my mobo along with gpu's and cpu. now, i ordered the EK S-Max NB block, and got through an odd shaped one, but it's only today that i've got all the rest of my bits through thus was going to install it all. i took off the big long heatpipe array that covered sb,nb,mosfet1,mosfet 2, and in doing so ruptured one of the heatpipes (it didn't take much pressure to do this...). anyway, the NB block they've sent i believe is the wrong one just put in the correct box, as i checked the s-max was the one i needed from the ek compatibilty chart before i considered purchasing... now i've got to wait for them to send me the correct block.
all i want to check is, from anyone's personal experience, is this the correct block i need?
many thanks
I have a maximus formula, bios modded into a rampage as it happens, and the correct EK NB block is definately the S-Max one.
the one they sent me is an L shape, which i'm presuming is completely wrong, not only cos the screw holes are hideously mismatched, but the 'tail' of the L would crash into the capacitors immediately next to the nb chip...
thanks for the quick response mate, would've read it earlier but had to go into uni. i've emailed the company in question, but they are yet to respond. hopefully i can get this sorted before the weekend otherwise i'm gonna be pc-less for ages :eek::rolleyes:
