NB-eLoop Fan B12-P
15 Nov 2010
Hey guys,
I heard somewhere that these fans are not good in Pull config, is this true?
NB-eLoop Fan B12-P
I am looking to replace my Gentle Typhoon fans with something slightly quieter.
It might be the NB-eLoop Fan B12-P or Noctua NF-P12.
(I looked at the NF-F12 too, but the P12 seemed to perform almost as well but much quieter).
Just looking at options and seeking some good advice.
Thanks
Yeah either will be good, I'd go with NB since it looks better :p
How much warranty does each have? Although decent fans should last many moons.
Well you heard wrong, if you look at most reviews they are very positive. B12-P is a great all round fan, the Noctua NF-P12 will be quieter but won't perform as good. But you may prefer silence over performance, especially if a few degrees difference in temperature doesn't bother you.
