NB_FAN header
28 May 2008
Can I use this like any other fan-header?
I have one more fan to go on my case in the Scythe Kama Bay, but this is the only fan header left.
UD5 or a different board? It's probably exactly the same as any other fan header, but in an awkward place for a kama bay. I run almost all my fans directly off molex, have you considered this? Choice of 12. 7 or 5V but not so easy to switch between
UD5...
I would switch one of the CPU cooler fans to this header so I can use the one closest to the front of the case.
My PSU is rather annoying with big chunky cables etc, and its not modular.
Well... Despite my case being the Fortress I had a hell of a time getting the side panel back on with my chunky cables getting in the way...
I've taped up most of the cables to the back of the mobo tray, but all my molex cables are taped in bunches at the bottom of the main part of the case.
