Ncase M1 v3 build for gaming
20 Apr 2015
I have just bought an Ncase M1 v3, which might be a bit of a tall order for my first build!
I want to build a gaming system that is fast enough to run max settings at 1080p. What I am planning so far includes:
I7-4790K or I5-4690K processor
Asus Maximus VII Impact Intel Z97 (Socket 1150) DDR3 Mini ITX Motherboard
Kingston HyperX Savage Red 8GB (2x4GB) DDR3 PC3-19200C11 2400MHz
OcUK GeForce GTX 970 "NVIDIA 970 Cooler Edition" 4096MB GDDR5 PCI-Express Graphics Card
Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E500B/EU)
Silverstone Strider SFX 600W Fully Modular '80 Plus Gold' Power Supply (SST-SX600-G)
Will all of that fit/match?
I need to think about fans/cooling next.
Thanks in advance for any advice.
That will all fit in the v3 without issue.
Cooling, I'd suggest a Noctua NH-C14 or a Cryorig C1 with an upgraded fan on the C1.
You'd just have to check the ram height for the C1.
Never been a fan of AIO coolers.
/Edit
Personally I'd wait for Skylake with it being so close now, just depends on when you need to build.
Thanks. I am not in a massive hurry to build, and the case won't be here for a few weeks. Do you think that Skylake will be freely available much before the end of the year?
I personally wouldnt wait for skylake. First it has to be announced, then be available, then you will have to wait for manufacturers to release an ITX board to go with the case.
I would get building as soon as you receive your case :D
Here's mine with a 295x2 and ATX PSU in it, so yes, a 970 with an SFX PSU will fit no problem :D
Skylake S will be, not so sure about Skylake K.
We'll know more in June when Computex comes around.
There will be quality m-ITX boards on release. I have no doubts about that!
Ok, it appears that my NCase is going to be a while.
I need to build another PC for a family member later in the year, so the current plan is to get something really small like the Silverstone SG13, build my PC in it for now and then transfer it to the NCase when it arrives.
Will the SG13 take that GTX 970 as the specs seem to say it is a couple of mm too long?
