So I'm looking for some alright-ish ND Grad filters (no need for pro quality, but decent enough quality). I'm not sure on a budget because for some reason I'm finding it hard to find many around to gauge how much they cost.
I've only seem super cheap Cokin ones or very expensive Tiffin ones (but even the Tiffin ones don't really seem to be commonly available and the thread size I want isn't available at all).
Which ones are commonly used by you guys? And where did you get them from?
