- 16 Nov 2012
Hi guys, could use a little help here
For the last few weeks every time I play a game, my PC crashes. Most of the time it's nearly instantaneous, but sometimes it will work for a few minutes first. No BSOD, nothing in the event log, no warning whatsoever, just instantly loses power and turns off then reboots.
Games I've tried, all with the same result:
- Unreal tournament 3
- Modern warfare 2
- F1 2013
- Black ops 2
- Fallout new vegas
I've tried throttling back my GPU and CPU as well as playing with voltages thinking this was an issue with an overclock, but no joy. Temperatures are lovely and low (around 30-40c).
The machine is 100% stable when not playing games, it runs 24/7 and never crashes, hangs or hiccups whatsoever running desktop tasks.
This morning I finally made some progress while trying UT3. It will ONLY crash when running at 2560x1440 or above using super resolution. If I leave the game at 1920x1080 it runs perfectly fine. Once I apply the resolution, my PC instantly cuts out.
I've tried completely uninstalling my drivers using DDU, rebooting and installing fresh with clean settings using all defaults but no joy. I've tried about 3 different driver versions too. I'm totally at a loss here.
I'm using Nvidia Drivers ver 344.65 on a Gigabyte Windforce GTX670 2GB.
Edit: Primary monitor is 2560x1440 (Dell 27" U2713HM).
If anyone can help, itd be much appreciated!
- Modern warfare 2
- F1 2013
- Black ops 2
- Fallout new vegas
