NEC 24WMGX3
4 Dec 2008
I've got two of these, one of them now appears to have a flicker, as if the refresh rate isn't right, which it is as no settings have changed, both of them are on the same PC.
It's not as bright as it used to be either, so I know it's about to die. Bought it from OCUK early 2009 at the latest. What's the warranty length with these? I can't remember.
I've just been looking at NEC's website, it appears they don't do this monitor anymore, if they can't fix my monitor, then what will I do? NEC doesn't do anything else like it.
This is a full HD monitor and I do use the HDMI inputs.
Just because they don't produce it anymore, doesn't mean to say they don't have any in stock for RMA replacement, which is what is the case I would think...
