nec ea294wmib 29"
6 Aug 2011
NEC MultiSync EA294WMIB 29" Professional Super-Widescreen LED Monitor
hi I just bought one of these monitors and I am very happy with it, but can anyone tell me what the usb ports are for and how to use them, as I cant find any information at all, I actually thought I could use usb storage to watch movies on it without the pc being turned on, but I cant get any thing to happen......
Its most likely a USB hub, will have a USB in port which splits into a few 'out' ports for connecting devices to your PC via the monitor.
From product spec page:
Input Connectors
DisplayPort, DVI-D Dual Link, DVI-D Single Link, VGA (2), USB hub (1up/ 4 down)
hi there thanks for the info, seems a bit pointless if that is the case though, there is 1 upstream usb so it looks like your right, that 1 will connect to the pc....
