**NEC MONITOR RANGE NOW IN STOCK AT OCUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
We now have a full range of NEC monitors in stock at OcUK, these are more aimed at professional and business use rather than gaming:-
NEC MultiSync E222W 22" Professional Widescreen LED Monitor - Black @ £149.99 inc VAT
Entry-level wide (16:10 format) office monitors - offering great flexibility and strong ergonomic features.
Features:-
- 22" (16:10) Highly efficient panel with only 2 backlights saves more than 30 % energy
- ISO 9241-307 (pixel failure class I)
- Ergonomics and safety complying to the highest industry standards incl. ISO 9241-307
- Low energy consumption with Eco Mode and unique Carbon Footprint Meter / Carbon Savings Meter
- Versatile and easy installation (VESA standard) with NaViSet and NaViKey
- ErgoDesign®: Height adjustable stand (110 mm) with 90° Pivot features
Specification:-
- Panel Technology: TN TFT
- Screen Size [inch/cm]: 22 / 55.9
- Pixel Pitch [mm]: 0.282
- Brightness (typ.) [cd/m²]: 250
- Contrast Ratio (typ.): 1000:1
- Viewing Angle [°]: 160 horizontal / 160 vertical (typ. at contrast ratio 10:1)
- Response Time (typ.) [ms]: 5
- Colours [Mio.]: 16.77
- Optimum Resolution: 1680 x 1050 at 60 Hz
- Supported: 1680 x 1050; 1440 x 900; 1400 x 1050; 1360 x 768; 1280 x 1024; 1152 x 864; 1024 x 768; 832 x 624; 800 x 600; 640 x 480
- Connections: 1 x DVI-D (with HDCP), 1 x mini D-sub 15 pin
- Bezel Width [mm]: 16; 16 (left and right); 16 (top and bottom)
- Dimensions (W x H x D) [mm]: 508 x 385 x 214; Without stand: 507.8 x 332.1 x 71.8
- Weight [kg]: 6.8; Without stand: 4.8
- VESA Mounting [mm]: 100 x 100
- Warranty: 3yr
Only £149.99 inc VAT.
ORDER NOW
NEC MultiSync E231W 23" Professional Widescreen LED Monitor - Black @ £179.99 inc VAT
Take your environmental initiatives to the next level with the 23" NEC MultiSync E231W, a widescreen LCD desktop monitor that enhances your desktop computing with bar-setting, eco-friendly benefits. The E231W features an LED-backlit panel that provides the same brightness as other panel types while using 35% less power. Compared to previous generation NEC LCDs, this model consumes less power overall, radiates less heat, uses less packaging, weighs less, utilizes recycled plastics in its production and is free of hazardous materials such as mercury, halogen and arsenic. These advantages, combined with an ergonomic design and a high-contrast screen, make this model ideal for enterprise environments.
Features:-
- LED backlight technology provides for low power consumption, improved recyclability and a design free of toxins such as mercury
- 4-way ergonomic design (110mm height-adjust, pivot, tilt & swivel) enhances your viewing comfort
- DisplayPort provides enhanced display connectivity and performance
- ECO ModeTM function and ambient light sensor help save power, reduce heat and extend the life of the display by manually or automatically dimming the brightness level
- 25,000:1 dynamic contrast ratio delivers amazingly detailed images and text
- Carbon footprint meter helps track and calculate the reduction of green gas emissions
- Dynamic Visual Mode enhances video and images with real-time optimization of brightness, color and contrast
Specification:-
- Panel Technology: W-LED TN TFT
- Screen Size [inch/cm]: 23 / 58.42
- Screen Aspect Ratio: 16:9
- Pixel Pitch [mm]: 0.265
- Contrast Ratio (typ.): 1000:1 (25000:1 (typ.) dynamic contrast ratio)
- Viewing Angle: 170 horizontal / 160 vertical (typ. at contrast ratio 10:1); 176 horizontal / 170 vertical (typ. at contrast ratio 5:1)
- Response Time (typ.) [ms]:5 (grey-to-grey)
- Optimum Resolution: 1920 x 1080 at 60 Hz
- Supported: 1920 x 1080; 1680 x 1050; 1440 x 900; 1400 x 1050; 1360 x 768; 1280 x 1024; 1152 x 864; 1024 x 768; 800 x 600; 720 x 400; 640 x 480
- Connections: 1 x DVI-D; 1 x DisplayPort, 1 x mini D-sub 15 pin
- Bezel Width [mm]: 19.2 (left and right); 19.2 (top and bottom)
- Dimensions (W x H x D) [mm]: 550.1 x 381.1 x 213.9; Without stand: 550.1 x 329 x 71
- Weight [kg]: 6.2
- Warranty: 3yr
Only £179.99 inc VAT.
ORDER NOW
NEC MultiSync EA232WMi 23" Professional Widescreen LED Monitor - Black @ £215.99 inc VAT
The EA232WMi is an update of the successful EA231WMi 23” with IPS technology. New features like LED backlight and Ambient Light Sensor reduce the already low power consumption. In addition, the production out of recycled plastic and mercury-free materials means less harm to the environment. Thanks to its excellent IPS image quality with wide viewing angels in a 16:9 screen format and a dynamic constrast of 25.000:1 the monitor offers a high level of ergonomic comfort.
Ideal for corporate customers with advanced office applications and multiscreen solutions in medium-sized and large companies.
Features:-
- Ambient Light Sensor - with Auto Brightness function always sets optimised brightness level according to ambient light and content conditions.
- DICOM Simulation - for straightforward radiological review applications.
- Ergonomic Office - full height adjustability (110 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
- Excellent image quality - wide viewing angels thanks to IPS technology for better viewing comfort and multiscreen solutions.
- Green Product Concept - Eco Mode and Carbon Footprint Meter / Carbon Savings Meter , Ambient Light Sensor.
- Input - Display can be used with two digital (DVI-D, DisplayPort) and one analogue input.
- Sustainable Office - low power consumption with LED backlight and ambient light sensor.
- USB Hub - 1 up and 4 down ensures perfect connectivity for any USB devices.
- Special Characteristics - Ambient light sensor for optimized brightness levels; Carbon Footprint Meter; Carbon Savings Meter ; DICOM Simulation ; ErgoDesign® : Height adjustable stand (110 mm) with 90° Pivot features; integrated USB Hub; LED Backlight Technology; NaViSet®and NaViSet®Administrator compatible; sRGB Support; TORO™ Design ; WindowsVistaCertifiedLogo
Specification:-
- Panel Technology: IPS TFT with W-LED backlight
- Contrast Ratio (typ.): 1000:1 (25.000:1 (typ.) dynamic contrast ratio)
- Viewing Angle [°]: 178 horizontal / 178 vertical (typ. at contrast ratio 10:1); 178 horizontal / 178 vertical (typ. at contrast ratio 5:1)
- Response Time (typ.) [ms]: 14
- Supported: 1920 x 1200; 1600 x 1200; 1440 x 900; 1400 x 1050; 1360 x 768; 1280 x 1024; 1280 x 960; 1280 x 768; 1152 x 864; 1024 x 768; 800 x 600; 640 x 480
- Connections: 1 x DVI-D (with HDCP); 1 x DisplayPort; 1 x mini D-sub 15 pin; USB (1 up; 4 down)
- Height adjustable Stand [mm]: 110
- Screen Tilt / Swivel / Rotate [°]: -5 to +30 / -170 to +170
- Screen Rotate [°]: 0 to 90 (landscape to portrait mode)
- Dimensions (W x H x D) [mm]: 550 x 379 x 220; Without stand: 550.1 x 329 x 71
- Weight [kg]: 7.5
- Warranty: 3yr
Only £215.99 inc VAT.
ORDER NOW
NEC MultiSync EX231W 23" Professional Widescreen TN LED Monitor - Black @ £199.99 inc VAT
Ultra-slim ‘Office Cool’ design, combining MultiSync® trusted performance and quality with new standards of minimalism and Eco innovation. A 23 inch wide TN TFT LCD with LED backlight technology, ideal for corporates that demand style and future proof technology and excellent picture quality.
The perfect compliment for the modern office and new developments in corporate desking, the NEC Multisync EX 231W features an extremely thin LED backlight panel in a design that puts a priority on the screen image and its positioning.
For demanding ECO users or those wanting the optimum working set-up, the EX231W include luminance and human sensors and the smallest stand on the market that offers full ergonomics. The panel can also easily be moved between VESA mounts.
Features:-
- ECO Innovation - low wattage LED, human and luminance sensors to save on power consumption. The slim and lightweight design reduces required resources, packaging materials and transportation energy requirements.
- Future-proof Technology - including two digital inputs (1 x DVI-I and 1 x DisplayPort), full HD 23inch wide format and USB for video-communication.
- Perfect Office Set-up - the extremely light head of the monitor allows installion in various wall and desk-mounted or dual/multi-monitor solutions delivering all the best in ergonomic standards.
- The Vision of the Future - the minimalistic appearance is a perfect match for modern office desking. The display itself is the dominant part with minimalist lines and a very slim frame, letting the image take precedence.
- Special Characteristics - Advanced connectivity with two digital inputs DVI-I and DisplayPort; Ambient light sensor for optimized brightness levels; Auto Contrast; Carbon Footprint Meter ; Ecologics and Ergonomics complying to standards EPEAT Gold and TCO 5.0; EcoModes; Human Sensor; LED Backlight Technology; Windows 7 compatible
Specification:-
- Viewing Angle [°]: 176 horizontal / 170 vertical (typ. at contrast ratio 5:1)
- Connections: 1 x DVI-I; 1 x DisplayPort
- Height adjustable stand [mm]: 110 (Landscape mode)
- Screen Tilt [°]: -5 to +30
- Screen Swivel [°]: -170 to +170
- Screen Rotate [°]: 90
- Bezel Width [mm]: 14
- Dimensions (W x H x D) [mm]: 540.2 x 401.3 x 215; Without stand: 540.2 x 318.3 x 47.7
- Weight [kg]: 4.1; Without stand: 2.8
- VESA Mounting [mm]: 100 x 100 (4 points)
- Warranty: 3yr
Only £199.99 inc VAT.
ORDER NOW
NEC MultiSync EX231WP 23" Professional Widescreen PVA LED Monitor - Black @ £239.99 inc VAT
Ultraslim ‘Office Cool’ design, combining MultiSync® trusted performance and quality with new standards of minimalism and Eco Innovation. A 23” wide PVA TFT LED Backlit display, ideal for the corporate that demands style, future proof technology and excellent picture quality with wider viewing angles.
The perfect compliment for the modern office and new developments in corporate desking, the NEC EX231Wp features an extremely thin LED backlight panel in a design that puts a priority on the screen image and its positioning. Ideal for multimonitor solutions due to PVA panel technology which allows extremely wide viewing angles.
For demanding eco users or those wanting the optimum working set up, the EX231Wp includes Luminance and Human Sensors and the smallest stand on the market that offers full ergonomics. The panel can also easily be moved between VESA Mounts.
Features:-
- The Vision of the Future - the minimalistic appearance is a perfect match for modern office desking. The display itself is the dominant part with minimalist lines and a very slim frame, letting the image take precedence. The advanced PVA panel technology provides outstanding picture quality with wide viewing angles.
- Special Characteristics - Advanced connectivity with two digital inputs DVI-I and DisplayPort; Ambient light sensor for optimized brightness levels; Auto Brightness; Auto Contrast; Carbon Footprint Meter ; DICOM Simulation ; Ecologics and Ergonomics complying to standards EPEAT Gold and TCO 5.0; EcoModes
- By gradually reducing the brightness, power consumption can be simply and quickly reduced even further at the touch of a button, which also brings about a reduction in heat emission.
- Human Sensor; LED Backlight Technology; PVA panel technology; Windows 7 compatible
Specification:-
- Panel Technology: PVA TFT (W-LED)
- Pixel Pitch [mm]: 0.266
- Contrast Ratio (typ.): 3000:1 (25000:1 (typ.) dynamic contrast ratio)
- Response Time (typ.) [ms]: 25
- Supported: 1920 x 1080; 1680 x 1050; 1440 x 900; 1400 x 1050; 1280 x 1024; 1024 x 768; 800 x 600; 720 x 400; 640 x 480
- Operating Temperature [°C]: +5 to +35
- Operating Humidity [%]: 20 to 80
- Storage Humidity [%]: 10 to 85
- Storage Temperature [°C]: -10 to 60
- Weight [kg]: 4.2; Without stand: 2.8
- Warranty: 3yr
Only £239.99 inc VAT.
ORDER NOW
NEC MultiSync EA243WM 24" Professional Widescreen LED Monitor - Black @ £299.99 inc VAT
NEC MultiSync® EA243WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient Light and Human Sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability. Moreover the display offers broad connectivity with four inputs DisplayPort, DVI-D, HDMI and D-Sub.
Ideal for the corporate that demand style and future proof technology.
Features:-
- Ergonomic Office - full height adjustability (130 mm), swivel, tilt and pivot functionality ensures perfect individual ergonomic set-up.
- Feature Set for Perfect Office Use - Integrated Speakers, headphone jack and USB Hub provide excellent options for office communication.
- Human Sensor - detects the presence of a person in front of the screen; display switches on/off automatically depending on the presence of the user.
- Image display - 24inch 16:10 TN with LED backlight.
- Vesa Mount (100 mm) - allows to install the monitor via various mounting solutions.
- Special Characteristics - Ambient light sensor for optimized brightness levels; Carbon Footprint Meter ; Carbon Savings Meter ; ControlSync® ; Customize Setting ; EcoModes ; ErgoDesign® : Height adjustable stand (110 mm) with 90° Pivot features; Human Sensor; LED Backlight Technology; USB ver. 2.0 (4 down / 1 up); Versatile and easy installation (VESA standard) with NaViSet and NaViKey; Windows 7 compatible
Specification:-
- Screen Size [inch/cm]: 24.1 / 61.13
- Screen Aspect Ratio: 16:10
- Pixel Pitch [mm]: 0.270
- Viewing Angle [°]: 170 horizontal / 160 vertical (typ. at contrast ratio 10:1); 178 horizontal / 178 vertical (typ. at contrast ratio 5:1)
- Optimum Resolution: 1920 x 1200 at 60 Hz
- Supported: 1920 x 1200; 1920 x 1080; 1680 x 1050; 1600 x 1200; 1440 x 900; 1400 x 1050; 1366 x 768; 1360 x 768; 1280 x 1024; 1280 x 960; 1280 x 768; 1280 x 720; 1024 x 768; 800 x 600; 640 x 480
- Connections: 1 x DVI-D (with HDCP); 1 x HDMI ; USB ver. 2.0 (4 down / 1 up); 1 x DisplayPort; 1 x mini D-sub 15 pin
- Height adjustable Stand [mm]: 130
- Screen Tilt / Swivel [°]: -170 to +170
- Dimensions (W x H x D) [mm]: 556.2 x 408.9 x 230
- Weight [kg]: 7
- Warranty: 3yr
Only £299.99 inc VAT.
ORDER NOW
NEC MultiSync EA273WM 27" Professional Widescreen LED Monitor - Black @ £329.99 inc VAT
The NEC MultiSync® EA273WM is the flagship model in the new NEC MultiSync® EA Series and unites excellent display quality, ergonomics with low environmental impact. The NEC MultiSync® EA273WM features an extremely thin LED backlight panel which results in an ultra-modern and slim design in combination with a premium feature set for the corporate office use. Ambient Light and Human Sensors enforce the sustainable product concept while offering improved ergonomics with 130 mm height adjustability. Moreover the display offers broad connectivity with four inputs DisplayPort, DVI-D, HDMI and D-Sub. Ideal for the corporate that demand style and future proof technology.
Features:-
- Green Product Concept - Eco Mode and Carbon Footprint Meter / Carbon Savings Meter Ambient Light Sensor.
- Image display - 27inch 16:9 TN with LED backlight.
- Special Characteristics - Ambient light sensor for optimized brightness levels; Auto Contrast; Carbon Footprint Meter ; Carbon Savings Meter Carbon Savings Meter, The Carbon Savings Meter calculates and totals the CO2 savings that have been accrued by using the monitor/projector in Eco Mode. The Carbon Savings Meter displays the estimated carbon savings information in kg; ControlSync® ; Customize Setting ; EcoModes ; ErgoDesign® : Height adjustable stand (110 mm) with 90° Pivot features; Human Sensor; LED Backlight Technology; Versatile and easy installation (VESA standard) with NaViSet and NaViKey; Windows 7 compatible
Specification:-
- Screen Size [inch/cm]: 27 / 68.6
- Pixel Pitch [mm]: 0.311
- Brightness (typ.) [cd/m²]: 300
- Viewing Angle [°]: 160 horizontal / 160 vertical (typ. at contrast ratio 10:1); 178 horizontal / 178 vertical (typ. at contrast ratio 5:1)
- Supported: 1920 x 1080; 1600 x 1200; 1280 x 1024; 1152 x 864; 1024 x 768; 832 x 624; 800 x 600; 640 x 480
- Connections: 1 x DVI-D (with HDCP); 1 x HDMI ; USB ver. 2.0 (4 down / 1 up); 1 x DisplayPort, 1 x mini D-sub 15 pin
- Dimensions (W x H x D) [mm]: 631.4 x 415 x 230
- Weight [kg]: 7.2
- Warranty: 3yr
Only £329.99 inc VAT.
ORDER NOW
PVA panels are as rare as hens teeth theese days, love them for the fantastic black quality they have.
So true and even this one is just a 23" 16:9 screen whereas my old one was a 24" 16:10. I'm quite missing the blacks now even though I'm l;oving the size of the dgm 27"
If nec released a 16:10 27" PVA screen I would buy it tomorrow.
