NEC MultiSync 24WMGX3 24" - Not powing on after sleep
3 Dec 2005
UK
Hi,
I have a NEC MultiSync 24WMGX3 24" and its been great except.....
When i put the PC into sleep the computer will power back on but the screen will not come out of sleep.
I have to reset the PC to get the wcreen to work again.
Is there a fix for this?
I have a similar problem with mine, I usually just flick the off switch on the back of the monitor off and on and it will usually come back on then with the power button on the front.
hi Macster,
Many thanks for the reply, ill try that then.
Hoping for a permanent fix, can these monitors be flashed with a firmware?
Mine does this too. It has become more problematic to turn the monitor on. It turns on and then shuts of in a couple of seconds. I have to turn off/on many times. Today I had to turn off/on continually for about 20 minutes.
It seems to me that the problem is with the internal PSU. Anybody found a fix?
Or how to disable standby completely?
