Need 2 monitors.
fiveub's Slave
1 Sep 2007
OcUK HQ
Im in need of 2 monitors. One 17" (non-widescreen) and a 20" widescren.
With £300 what am i looking at? Please state 2 monitors you would get if you were in my situation.
(they will be setup as dual monitors and wall mounted)
Thanks, Ben.
If you can find one second hand the 20" ought to be the NEC 20WGX2 (got mine for £120). Best 20" screen by a mile. New they will use up all your budget.
2nd choice would be the Dell2007WFP
http://www.overclockers.co.uk/showproduct.php?prodid=MO-011-DE&groupid=17&catid=948&subcat=
But that costs £252 so it would only leave £48 for your 17" screen which isn't a lot and won't get you a new one however that would get you a decent one from the bay.
