I'm currently running a 24" Dell U2412M and I'm finding myself squinting at it quite a lot these days, so I need to upgrade. Comparing to a 28" diagonal doesn't seem that much bigger, so I think I need a 32".
I'm not expecting to find a 16:10 monitor like my Dell. I like to play flight sims and when my Dad swapped his old IPS monitor for a BenQ VA I was impressed how much clearer the stars stood out in the night sky because of the better black levels/contrast, so I think I want a VA panel. I don't do colour critical work like photography so hopefully I won't mind the less accurate colours compared to an IPS, although I've read some comments about severe ghosting with a VA which concern me.
I'm thinking 4k will be useful for productivity even if I can't run games at that resolution with my 1070ti. Presumably it will upscale anything I run at 1080 or 1440?
I don't do twitch gaming as I suffer from quite bad motion sickness so can't even play Assassin's Creed for more than a couple of hours on my 60hz TV and some games are much worse. So I'm not sure I have any need for a 120/144hz monitor and I know 4k at above 60hz monitors are out of my budget but if I get a 2k with a high refresh rate I'll try it of course.
I guess something with Freesync that works with the 1070ti might be nice but I've never experienced Freesync so can't really say if I'll benefit.
I know some monitors like my Dad's BenQ feature low blue light for reduced eye strain, so that might be nice to have.
Budget I'm thinking £300-500.
I want to mount it on a monitor arm, so a central VESA mount point is important. What I want to do is be able to move the 32" to a higher position for flight simming and position my touchscreen below it. If I had a dual monitor arm like this (I know this one only supports up to 27") mounted off to the side of the desk, would that allow me to move the main monitor up and down vertically without it moving in any other direction and then bring the second monitor in from the side to underneath the main one, or would I need two separate arms to do that?
Competitor link removed, if OCUK don't sell that item either link to the manufacturers website or just list the make and model. Thanks.
