Need a 2.1 setup with connections to allow me to connect xbox360+PC & headphones
18 Oct 2002
Can anyone recommend a 2.1 set of speakers that i can have on my desktop (sub under desk) that allow me to connect my PC and XBOX360 to at the same time (autoswitching or a switch to select between them) and also have a headphone output for some late night gaming?
Budget of round about £100
Many thanks for your help
Spudgun
You ain't been ignored, I looked the same as you could in the store cause I cant really help with some of aspects you asked for. :)
z4 will only do headphones and pc at same time, and the headphones plug in to the wired remote box and is a much worse sound input than plugging the headphones straight in to the soundcard.
What you need is an integrated amp maybe buy a cheapo and some half decent bookshelfs.
