need a 2 slot GPU for 4k gaming
18 Dec 2003
heybridge, nr maldon, essex
2080 super or 2080TI
i have a TI now but it won't fit in my new shift X case :(
so selling it.
will any AMD cards do 4k well? thinking the XT lines
That case comes with an included riser cable to mount that gfx card vertically if required - does it not fit in the case at all or i something in the way where you wanted it?
its to big either way, you can switch sides but not sure it will go anywhere else in the case.
another thought, if i were to go watercooled loop again, buying a block for the gpu would solve the issues would it not?
I'm running a Radeon VII, which is a two slot cooler. It easily handles 330x1440p so would probably be OK at 4K as long as you're not expecting 2080 Ti performance. There are probably better options out there but I thought I'd mention it as an option. I think the watercooling or aftermarket cooler option on the Ti is the best option to be honest. Or a new case.
thanks. i'm thinking about the 5700 XT possibly. but also wc it but didn;t consider an afternarlet cooler for the palit if they do one. that could solve the problems!
