Need a 5930k CPU cooler for tomorrow!
Caporegime
30 Jul 2013
My Swiftech 240x pump died last night, and Swiftech are doing an RMA but that involves them sending me a new pump via snail mail from the States and me fitting it myself.
So either i'm without a PC for a few weeks(!) or I buy an interim replacement cooler from Overclockers.
What is a good option? My 5930k was running nicely at 4.4Ghz but if I have to do without an overclock for a few weeks it's not really an issue.
You can pick up a cheap Arctic Cooling Alpine 20 PLUS CO for about £13. It does a decent job of cooling those cpus at stock. And they are VERY easy to fit so makes life easier. So Cheap, Does the job, easy to fit. Perfect for a temp solution.
Thanks, I got the Phanteks PH-TC14S
It'll do for now, certainly doesn't compare to a Swiftech H-240x though. I did the same Overclock I usually run 24/7 for lolz and it went to 80°C+ and lasted about 2 mins in the Asus Realbench stress test.
