Need a bit of FAN help
23 Mar 2010
Good evening
I've been having some issues with controlling fan speeds.
I've got a Corsair H80i using latest version of Corsair Link. I can manually change the fan speeds of the fans on the radiator with no issues however I can't seem to change either of my chassis fans.
They're both Factal 120mm fans which came with the Define R5. I've tried them into various fan headers on my motherboard (Maximus VII Ranger) but they seem stuck at 650rpm (I've had this upto over 1500 on a previous motherboard)
Any ideas?
Cheers
One of the fans is connected into the fan controller, I've changed the switch between the 3 settings and it doesn't appear to make any difference.
The other fan is connected to the CH_FAN3 header
