Need a bit of help.
25 Jan 2009
London
What do you call the accesory/disc for the dremel for cutting through thin metal? e.g. motherboard tray.
Noob question I know.. but I just really haven't go a clue what its called.
It's just called a Cut-Off Wheel. There are several sorts - there is a No 409 pack of 36 pieces which are about 1" dia and aren't bad if used correctly but can be a bit flimsy, and you can also get 1.5" dia Reinforced Cut-Off Wheels which are stronger due to the reinforcement.
Watched the vids. Very helpful !!! think I can do some mini-projects for my PC case with just the dremel (my only tool for modding :()
Thanks again.
