Need a bit of worldly advice
26 Oct 2012
Sorry this may be the wrong subforum to post this in...in fact none of them looked like the right ones. Anyway;
Back in October 2011 I bought a "Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System from OcUK - I still have the receipt etc :)
It came with an OEM version of Windows 7 Home Premium 64 bit pre-installed and subsequently to that I have upgraded (via online download) to Windows 8.1 Professional 64 bit...so I have no physical disks at all.
I now want to do a complete reformat, get rid of the chaff n' crap and take it back to Win 8.1 but without the disks I have no idea how to go about it. I could buy a copy of Win 7 64, they are relatively cheap nowadays, and then do the online download again (I hope) but I'm kind of thinking "why should I when I theoretically already have bought Win 7 with the PC?"
Can anyone suggest the best way to go about this?
Ahh - brilliant! If I read that correctly then, I don't need to reformat or have the disks - I just type in my Win 8 product code and it will reformat and do everything online? I never knew it could do that - in the old days when I'd do a reformat I couldn't even get online until windows was fully installed!
And this will wipe everything? Even illicit handbag & shoe shopping websites, all references to Pokemon, any malware or whatever else dodgy stuff like Somalian bankers wishing to track soon-to-be-wealthy relatives that has possibly got on the PC?
You can just upgrade the system leaving all the files such as pictures/movies/music etc. I don't recommend upgrading without wiping everything out as it can create problems. When you upgrade the system I believe its going to be this same as Windows installation in which you can format the harddrives/partitions on which are your files.
You should get the option to download an Iso and make a usb stick with it. From there I think you can do a complete reinstall using the fancy recovery/reinstall options in the modern ui sections of Win8
Thanks for all the information guys. I'm starting to back up all my photos and music - the rest I want I can just reinstall, nothing is really 'mission critical'.
One final question (I promise!) - what size USB do you think it will ask me for. I have an old small one (according to my wife!) but I can "borrow" one from work if I know the size.
You can run the install from Windows, no need for USB. During the installation you can wipe the drive you currently have the OS on. ;)
Edit:
BTW you should get away with 4gb, but I personally use 8gb for OS install's.
