Need a budget telephoto for Nikon D40
26 Jun 2005
I'm trying to source a telephoto lens for my sisiter in-law. She's constrained by budget and unfortunately a 70-300VR at £300-330 is over the limit! It's mainly for wildlife shots and her other lens is the 18-55 Kit lens. Any other lenses I should recommend or keep an eye out for?
A Sigma 70-300 APO DG Macro Telephoto? No VR but it's a great budget lens (with reviews to back it up), I use to have the non APO-version for my Canon, great price for a relatively sharp lens.
Apart from the Sigma mentioned above, its natural competitor is the Tamron 70-300mm F4-5.6 Di LD Macro.
It can be found brand new for around £120, that's in the UK too, and it has the AF motor so AF works on the D40. (It's the D40 that needs the powered lenses isn't it?)
I've owned both lenses in Pentax fit, and they have their strengths and weaknesses. Purple Fringing was evident sometimes in the Tamron, although I never really found it a problem and could be processed out anyway, and the Tamron was arguably a little sharper than the Sigma.
The Sigma is an all round better lens I think though, although it's about £50 more expensive in it's APO guise. The non APO version can be found for £109 though, which is even cheaper than the Tamron, and it still has the AF motor (a non motor version is available for £10 less). Non APO Sigma vs Tamron is pretty equal I think.
I've still got the Sigma, but gave the Tamron away to a mate, so that probably tells you all you need to know about what I thought between the two!
There are plenty of reviews of the two lenses though, as it's a commonly asked question when people are looking for a budget zoom.
My vote is for the Sigma 70-300mm f/4-5.6 APO DG Macro Lens as well. Ive been using it for a while now on my D50 and found it to be a very good lens for the price. Although this lens does not have a build in AF motor, so on the D40 you will only have manual focus, but as I have found I tend not to use AF and it spends most of its time on manual as i prefer the control. If you want to see some photos taken with this lens follow the link in my sig to my site and 90% of the photos on there are taken with that lens.
Just checked out your link greywolf, and just wanted to say there are some really lovely pics on there!
