Need a case big enough for a full watercooling loop
18 May 2009
Glasgow, UK
Hey folks - I'm pretty new to this whole lark but I'm finalising my build just now for the first computer that I'm going to build - can posts specs if you want but they're not really important to this thread.
Since this is my first time I want to do things bit by bit - in this order of buying parts:
1. Build a PC and do all the cable management for good airflow
2. Achieve a stable overclock on my processor
3. Buy and build a CPU watercooling loop
4. Expand this to a GPU/Chipset loop
5. ???
6. Profit
(Sorry for the last part - seemed essential!)
Anyway can you recommend me a case that will get me through all this - was going to go for the Antec 902 but it looks too small to get extra loops in!
Coolermaster HAF 932 is built for what you want. Just comes down to whether you like the looks as it'd very marmite.
The silver TJ07-SW retails for just over £200... although Overclockers dont seem to be selling it at the moment. Cant recommend this case enough
nothing wrong with the HAF and it can take a tri rad I think you would call it on the top or 3 120mm fans even would be better
must admit it looks a bit busy I should say
