Need A Case Slightly Larger than the Corsair 750D
22 Jul 2004
Thick rads fit a little too uncomfortably in this case. I'm looking for something a bit more spacious but not too much larger, i.e 4cm more height just for rad space at the top and 4-5cm more depth so I have a chance at fitting a thicker rad in push pull at the front and fitting my pump and PSU in comfortably. Width is just about OK for me, but if it needs to be balanced by making it slightly wider then that's fine.
Can't fit a cube case or anything too tall under my desk, and would prefer castors to wheel it around as thick rads make it too heavy for me. Trouble is, castors add to the height and limit my selection. Another issue is that thick rads really need a push / pull fan configuration and therefore you need another 25mm space on top of the extra needed for the the thick rad. I'm really not sure there is a case that is just the right size with castors. I'm literally going to have to move house to accommodate the case upgrade that I really want.
