Need a Case with 6+ HDD mounts and ...
25 Jan 2006
Gateshead, Newcastle
Need a Case with 6+ HDD mounts and lots of fan mounts too. i would need to be able to cool the hdd's with some fans and have as much air flow as possible to keep my drives cool. black if possible and it would be nice to have a window on the right of the case so i can see my components
Stacker? has mesh rather than a window
UFO thing, huge cube with about 10 120mm fan mounts :eek:
Aerocool baydeam - stacker copy, cheaper not as good quality
Gigabyte Aurora if you are willing to use the floppy bays for HDs
Lian Li v2000
Lian Li v1000+ (just about, as long as your PSU is not modular)
Also any mid sized Lian Li with one of these: http://www.lian-li.com/Product/Accessories/HDD_Kits.htm (same goes for a thermaltake with one of those kits, but... thermaltake)
Akasa Eclipse if you use the extra hdd mounting bay that hangs below the psu, depends how big your cpu cooler is though.
Most cases have 120mm fans blowing across the hard drives, even my Zen has that feature. :p
To expensive, especially considering the superior cheaper options for what he wants. :)
TJ07 is to overpriced for what it is sadly, cracking case just not worth the price tag.
something like a stacker case or a lian li pc70 if they still make them
also what about lian li v-1000, Lian-Li PC-101, PC V1100, Lian-Li PC-S80, Lian-Li PC-G70
PC70 has been replaced by the G70, which is a 120mm version of the PC70. :)
S80 would be ideal, but a lot of money for what it is.
Chieftec Bravo Full Tower Chassis, upto 8 hdds, air cooled by 3x 92mm fans, hard to get these cases now though.
all in all the fans for this case are:
3x92mm for the hard drives
2x92mm for the side panel
2x120mm for the rear
