Need a cheap build for my spare GFX card
14 Dec 2003
Glasgow
I'm looking to build a cheap pc and stick my spare GTX560Ti inside it. Need something which will run games - mostly just WoW at the moment but hopefully some other things. The thing is it needs to be a cheap as possible with some good bang for those few bucks!
CPU, Motherboard, RAM, PSU, Case
I will source the rest such as monitor, hard drive, kb/mouse etc... from spares and other places.
I will be keeping my eye on MM but for now I could do with some new build specs. Ideally the cheapest possible under £200 although even less would be better
YOur not going to get much new for £200...
In my head,
AMD wise, id go for a 6300 and even if you went for a cheap 760g motherboard and 8GB 1600mhz RAM, thats £200 already.
Intel wise, the i3 and a H81 motherboard with 8GB of 1600mhz RAM comes near to £200 anyway..
Secondhand is the best your going to get on that budget, sorry.
