Need a CHEAP headset
16 Nov 2011
Nottingham
And by cheap, I mean cheap. Looking for a headset for around £10-15 MAX. The mic will only be used for voice communications, so not looking for audio quality really, just one with a decent mic.
Was looking at the Microsoft LifeChat LX-3000, but that's really pushing the budget at a massive £14.49
Please let me know any suggestions and even better if I can get it off OcUK since I need it asap.
Thanks in advance
The Microsoft Lifechat LX-3000 is decent, and is about as good as you'll get for your budget.
If you're looking for a stand alone microphone I highly recommend the ZM-MIC1.
some of the cheaper logitechs may be worth a look, used a few pairs in the past and the mics were decent.
I know a lot like the speedlink clip on mics also
Doesn't matter anymore guys, using my iPod headphones for now as they have a reasonably good mic implemented.
