Accell's DP 1.4 cables are VESA certified. Currently using a "Delock DisplayPort cable 8K 60 Hz 2 m DP 8K certified" (itemnr.: 85660) myself without issue. You can easily find it on google. Been pushing 3440x1440p 144hz over 2m without issues. You don't want to cheap out on your DisplayPort cable but also not pay through the nose for one. As long as you stick to a VESA certified cable you should be safe. VESA has a list of who is certified and what products are as well. You can look at the list -> here <-
How long a cable do you need? If you need a long cable, go fibre-optic, though you will pay through the nose (albeit less half what I paid last year.) I had a poor experience with Lindy 5m copper cables: they were listed as Displayport 1.4 but when they arrived were clearly labelled as Displayport 1.2 and indeed did not work.
