Need a flexible arm from a lamp..what are they called?
Caporegime
13 Jan 2010
Llaneirwg
I need a flexible arm, one of those you get on a lamp but just the arm, the stiff ones that bend to any shape, but I can't find a cheap one anywhere!
What's the proper name for them?
'Gooseneck' might get you started, but they tend to refer to pre-made goods like mic and lamp arms. Add 'pipe' to the search and you may get better results.
Edit: That wasn't in response to the first reply, I was just slow to post!
