need a gaming laptop, circa £1500
18 Sep 2008
It will be my dedicated game playing machine, to watch a few movies.. its basically to plugin my new projector, so I wont really be using its own display much
will need to chew up 1080p games
512GB+ SSD +
how much noise do mechanic HDD's make in them?
Also, if I connect the projector to the laptop, will the projector be limited by the laptops display?
512GB+ SSD +
Hi marktruman,
Could be a well timed enquiry,......
Under budget, over spec and will output 4K @ 60Hz to your projector on the HDMI 2.0 port:
HDMI 2.0 - Higher Frame Rate, Higher Potential
The era of true 4K Ultra-HD is upon us! The untapped potential of 4K resolutions is realized through HDMI 2.0! Unlike HDMI 1.4 which only supports 8-bit colour and 30 FPS, HDMI 2.0 can display games like never before! Supporting up to 18 Gbps transfer, the true potential of 4K resolution is realized through 12-bit colour and 60Hz refresh rate! Finally see your favourite games how they were meant to be seen, in true high definition
Was £1,899 and is a limited quantity early Black Friday deal.
Check it out.
Regards,
Gigabyte UK NB Team
Hi marktruman,
Check it out.
Regards,
Gigabyte UK NB Team
that does look good, does the HDMI 2.0 support older HDMI leads?
maybe a silly question
Hi marktruman,
It's not a silly question,,,,,,
But in answer, "yes" the technology is backwards compatible and older generation leads will fit, and transfer data at the faster speeds offered.
Hope that clarifies.
Regards,
Gigabyte UK NB Team
