Need a good wireless card (Vista x64 compatible)
Man of Honour
29 Jun 2004
Oxfordshire
Hi guys
Since I've come back home, I've had to use my laptops wireless connection to the livebox then use an ethernet cable to my PC to share the connection
This is quite messy, and I dont like having my laptop on 24/7
Need a good wireless card to sort this problem out
I know a couple of people who bought wireless cards with Vista and they didnt work (either software problems or just generally didnt work) so thought I'd ask the experts and get your opinion on which one is best for me
Around £20-30 if possible, it's going to be connecting to an Orange Livebox is that helps at all, and I'm about 10 meters away from the box
Cheers in advance guys
I would see what cards are available and then take a few that is within your budget. Then go to the manufacturers webpage and see if they have Vista drivers.
That might remove some of your choices, then with the ones that are left google them see if there is people that are having problems with these cards and Vista. Hopefully by now you should have at least one card that seems to work good with Vista and then purchase that one.
