Need a laptop for light gaming around £350ish
10 Jan 2006
Scotland
Can anyone help spec me a laptop for around £350, mostly going to be used for internet / movies and the usual stuff but also looking for something that would do a bit of "light" gaming. Likely older games, but also possibly new-ish games at lower settings.
I've seen that the AMD A4-5000 can be had cheaply and will run stuff like Bioshock infinite on low and dirt 3 on low.
Basically are there any APU/CPU-GPU combos about at the moment that should provide decent bang for buck that I should be looking out for.
Thanks all!
That seems like a pretty good suggestion, found some reviews of it as well. Seems to be the sort of thing I'm looking for and near the budget too which is great.
Anyone got anything else I should be looking at?
Edit: Perhaps with a bigger screen, the laptop won't be carried about the place, it'll just be for in the house use.
My girlfriend wants to sell her asus n53sv with an i5 and gt 540m 2gb, 8gb ram and 500gb hdd. Very decent machine and is going to be your best bet if you don't mind buying a used machine. But then again with this sort of budget you don't have many options with new laptops.
I'm sure this isn't an attempt to sell it ;)
But just in case, for future reference, no trading is allowed outside of the members market.
On topic, I would suggest a used machine. You will be able to get a-lot for your money buying used. Something with an i5, 8GB of RAM and an HD5650 would be in budget for example.
First problem: Core 2 Duo 1.3GHz and GT335M for £400? I think not!
Second problem:
We, Overclockers UK (OcUK) are happy to provide the resources of these forums to responsible individuals without charge. They cost a substantial amount of money to maintain and use considerable amounts of bandwidth which is paid for exclusively by us. As you know OcUK are in the computer hardware business and therefore the promotion of OcUK's competitors is forbidden. Examples of promotion are :-
- Posting links to competitors websites
- Posting links to reviews that promote competitors
- Quoting the names or contact details of competitors
- Offering to provide the names or contact details of competitors
- Hinting about product availability at competitors and their pricing
- Using the forums to notify a member of intent or actual supply of names or contact details of competitors
- Listing competitors names, URL's or e-mail addresses in signatures
- Listing competitors names, URL's or e-mail addresses in profile
- Posting links to or the mentioning of auction sites
- Disguising attempts to do any of the above
http://forums.overclockers.co.uk/faq.php?faq=vb_read_and_post :)
