- 9 Aug 2019
I currently use the NZXT H500 case which has been great so far. However I recently decided to water cool my 1080 ti.
My current setup is a Ryzen 7 3700X which is cooled using the NZXT X52 and my GPU is cooled by the Corsair H55. Both items are doing a good job for what I require.
However since the NZXT H500 has limited space for AIO's I'm finding things getting a little warmer than I like since adding the AIO to the GPU as the now single 120mm exhaust fan that's trying to push all the warm air out of the case is struggling a little bit. I have both AIO's pushing air into the case but I thought it better than having them push warm air out of the case through the radiators. Bit of a devil and the deep blue sea situation.
So I need a case with more fan options I'm thinking in order to increase the exhaust options to get that warmed air out faster.
The two cases I find attractive are
https://www.overclockers.co.uk/lian...ied-aluminium-midi-tower-black-ca-77k-ll.html
https://www.overclockers.co.uk/phan...-tower-glass-gaming-case-black-ca-07y-pt.html
Are those a good choice for my price range of around £200 or is there a better option that I'm missing.
Thanks in advance for any advice offered.
Sorted, I got the Evolv X, everything is fine now.
