Need a little help on final spec
8 Jan 2007
I'm in need of a new system as my old AMD Barton is not quite cutting it for music creation anymore. Plus the old 4200ti isn't going to cut it with Stalker and Bioshock :p
Here's my seventh or eighth parts list:
CPU:
E4300
Cooler:
Freezer 7 Pro
Memory:
Crucial Ballistix 1GB
Motherboard:
Gigabyte GA 965P-DS3
GFX:
Sapphire X1950Pro
Case:
Antec P180
Hard Drive:
Samsung Spinpoint 320GB
DVD Drive:
LG ?
PSU:
520w Corsair
Media:
AKASA card reader
existing 1212m soundcard and copy of Win XP.
Half of this would be from OC and the rest from another site. It comes to around £550. I could push my budget up to £600. I don't want to go any higher.
Which components would you change/upgrade, bareing in mind that:
1. it need's to be very quiet (I record vocals a few meters away from the computer).
2. I plan to overclock, but not at the expense of a noisy system. Probably a moderate overclock.
Does anyone know how long the cables are on the Corsair PSU. They need to be quite long for the P180 case.
Thanks for any help :)
£592
For what you need the pc to do at that budget it is kind of hard, but i have gone for 2GB of ram and the E6320 for it's 4mb cache, as i feel they will give you the best performance in the fields you stated.
