Is this a good spec
Mobo - Gigabyte GA-P35C-DS3R (Socket 775) PCI-Express DDR2 & DDR3 Motherboard £82.24
CPU - Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz(1066FSB) £148.04
CPU cooler - Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775) £17.61
Ram - OCZ 2GB DDR3 PC3-10666C7 1333MHz Platinum (2x1GB) Dual Channel DDR3 £105.74
Graphics - HIS ATI Radeon HD 3870 XT ICEQ3 TURBO 512MB GDDR4 TV-Out/Dual DVI/HDMI (PCI-Express) x2 £152.74 each
Case + PSU - Coolermaster CM-690 Dominator / Coolermaster Real Power 520w Modular Power Supply - Bundle £110.43
DVD RW - Asus DRW-2014L1T 20x DVD±RW SATA Dual Layer Lightscribe ReWriter £23.49
Monitor - Belinea 2225S1W 22" Widescreen LCD Monitor £146.86
Total £932.77
(all prices include vat)
I only realy wanted to spend around £800 but i couldnt make a spec for less, so if anyone could recommend cheaper items with the same performance that would be great
i dont want an asus mobo, i no some are cheaper than the mobo i chose but i have had issues with Asus Mobo's so i wanted to stay away from them.
thanks in advance
** edit linked correct CPU
Total £932.77
thanks in advance
dunno what you think?
