Need a little help with build I'm doing.
Permabanned
19 Jul 2012
Buckinghamshire
I'm building for my wife a PC. I'm gonna use a BitFenix Prodigy Mini-ITX Cube Case. I have XFX 650watt PSU and RAM. Just need CPU and ITX mobo.
This is the CPU I've been looking at.
http://www.overclockers.co.uk/showproduct.php?prodid=CP-430-IN&tool=3
And this ITX mobo
http://www.overclockers.co.uk/showproduct.php?prodid=MB-406-GI&groupid=701&catid=5&subcat=2071
I have this RAM.
http://www.overclockers.co.uk/showproduct.php?prodid=MY-114-GL&groupid=701&catid=8&subcat=
Would all this work together? looking for a pc that my wife and son can play with. maybe some gaming too.
Thanks
Yeah it will work..
Was just giving you a better option if you were buying now (which i thought you were :))...
That is good RAM though. :)
Sorry for DP, can't edit at work.. :)
On the GPU front. Grab a secondhand GTX 460, they are around £50 and will play a lot of games really well.. I had one before my 570 and it never really struggled.
Make sure you get the 1GB version.
1 gb version would be fine. Only my son is playing games. It would be very kiddy games so no need for 2 gb version. Never did a mini itx build before. Not worried about gpu.
