- 26 Aug 2004
- South Wales
I got the stuff a little over 2 months ago, but after leak testing with a kink, and then moving the tubes around i managed to get a little leak right at the barb where the tube was kinking, like in the pic below.
So a couple of days ago i removed the rubber grommets over the holes in my case and managed to get both tubes through 1 hole at the bottom without any kink. it's a bit of a squeeze but only just, would it work fine this way?
i don't know if i screwed up the barbs by using pliers on them instead of a spanner to tighten them because they were a bit sharp afterward, and i cut my thumb a bit on one of them. would this be any reason i got the leak before? or was it the kink and the fact i moved the tubing?, because where the tubing has been over the barbs you can see it's got a circular cut in them.
also i don't like the plastic clamps that came with the stuff, should i buy worm drive clamps (jubilee clips) and just carry on with putting the tubing through just the 1 hole in the case?.
also mind the dust
Thanks
also mind the dust
Thanks
