- 14 Dec 2005
yo,
Well ive just recently upgraded my gfx from x1900 crossfire to 8800gtx, but theres one thing that gets my scratching my head,moniters.
Since these cards are really made for high resolutions and you like playing with a 19inch what is the best way to go, i currently use a Viewsonic VX922 but you are restricted to using 1280x1024.
I know you could get a bigger lcd for a higher resolution but i usually only play FPS games and i feel 19inch is big enough.
So my question is, for my situation is a CRT the best way to go for using high end resolutions?
Thanks for any info on this
