Need a machine for work
20 Mar 2004
We're thinking of building a new machine at work and I need help picking out, or building, the best 1 for the job.
We're be using the machine for mainly backups, virus scanning and doing hard drive integraty tests.
The key here is speed and multi-tasking, at the moment we use a few different machines for this job, but they're pretty old and can take ages to transfer date. We Need something that can copy data from several hard drives at once without slowing to a crawl.
Price wise, we'd like to keep under the £500 mark, I have been looking at the value machines from OCUK and they all look pretty good to me, but we need a bigger hard drive, at least 1TB.
ct Name Qty Price Line Total
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - Retail Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - Retail £139.57
(£163.99) £139.57
(£163.99)
Gigabyte GA-P55-US3L Intel P55 (Socket 1156) DDR3 Motherboard Gigabyte GA-P55-US3L Intel P55 (Socket 1156) DDR3 Motherboard £68.93
(£80.99) £68.93
(£80.99)
Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGV34G1333ELK) Patrtiot G Series Sector 5 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Dual Channel (PGV34G1333ELK) £68.08
(£79.99) £68.08
(£79.99)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £55.31
(£64.99) £55.31
(£64.99)
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) £34.03
(£39.99) £34.03
(£39.99)
Sapphire ATI Radeon HD 4550 "Low Profile" 512MB GDDR3 Dual DVI/HDMI (PCI-Express) - Retail Sapphire ATI Radeon HD 4550 "Low Profile" 512MB GDDR3 Dual DVI/HDMI (PCI-Express) - Retail £28.08
(£32.99) £28.08
(£32.99)
Antec VSK 2000 Midi Tower Case - Black Antec VSK 2000 Midi Tower Case - Black £26.37
(£30.98) £26.37
(£30.98)
Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £12.76
(£14.99) £12.76
(£14.99)
total £508.93 inc VAT
beast
(£163.99) £139.57
(£163.99)
(£80.99) £68.93
(£80.99)
(£79.99) £68.08
(£79.99)
(£64.99) £55.31
(£64.99)
(£39.99) £34.03
(£39.99)
(£32.99) £28.08
(£32.99)
(£30.98) £26.37
(£30.98)
(£14.99) £12.76
(£14.99)
beast
I would probably go with this build.
There are other cases you may want to consider:
http://www.overclockers.co.uk/productlist.php?&groupid=701&catid=7&sortby=priceAsc
You could also get the cost of the build under £500 by going for the Samsung F3 500GB hard disk:
http://www.overclockers.co.uk/showproduct.php?prodid=HD-081-SA
in my view the above spec isn't best for what you need. You stated you need a computer capable of transferring large amounts of data without slowing to a crawl, indicating you need very high HDD speeds. You dont need an i5 for this kind of task, or a dedicated gpu.
If it was me, i'd go for a system based about the 785g chipset, socket am3. get a fast amd dual cpu in there and some reasonable ddr3. The integrated gpu on the mobo will be more than enough for what you need. Then spend the rest of the money to raid some HDD's, perhaps 2 samsung f3 1TB, or 3 samsung 500GB, maybe even an ssd. This type of mahcine will be far more suited to what you're looking for.
Sorry for the late reply, we've had a quick meeting about this machine and I have a few more questions.
But I'll give a better description of how we intend to use the machine.
We plug other hard drives in, normally via a USB caddy, we then virus scan the drive, copy over any essential date to a backup drive, wipe the hard drive then copy the data back across.
Depending on how busy we are, we could be doing several hard drives at once.
At the moment we're using USB caddies for ease of use, so are there any USB 3.0 boards out there that we can use?
Or are there any motherboards that support some kind of hot swap system for sata drives? So we can swap drives without having to restart the machine?
My manager was quite interested in this, though I confess I don't know anything about raid systems...
Can you explain how it would work and how it would benefit us?
