Need a Mame frontend
20 Mar 2004
I'm setting up a machine at moment which is going to be primarily used for mame purposes. As such I want it to boot up straight away into frontend and also be controlled by the control panel rather then using a mouse/keyboard.
I've tried using MameUI, but the major problem I have with it, is that you need to press Enter to start a game, while CTRL is the main fire button. I've looked around the MameUI's option and I can't see a way of changing it.
If any can suggest a frontend that meets my needs, or knows a way of changing MameUI, it would be greatly appreciated.
Cool, I'll look into it.
I'm doing this at work as a side project, so I won't actually be able to test anything out till wednesday, so I'm open to anymore suggestions in the mean time :)
